Speedster project update, pulled pan found oil leak problem ..
Posted: Tue May 05, 2020 12:42 am
As some of you know I had a major oil leak at the passenger pan arm when I started the speedsters engine. I also had a blown head gasket. I have addressed the blown head gasket problem and moved on to the oil leak.
here is a link to the previous discussion as to the head gasket
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=12267
I have now removed the crankcase and I found the oil leak problem. There is a depression at the pan arms on both sides. If you use a straight edge The pan is straight just at a narrow edge near the inside of the lip. I have shown in the following pictures a area marked with blue Xs. That area is level with the rest of the pan, but sinks down into the area marked with the red Xs. There is not enough sealing area at the narrow strip marked with the blue Xs. But it explains why I missed the depression when straightning the pan on my pan jig. The narrow strip would be touching the pan and give a false reading when I tested it with the feeler gauge and shining a light inside the pan. That area is going to be almost impossible to straighten with the pan arm in the way. My pan has been modified for outside oil lines, and also has a small dam inside to slightly raise the oil level. So going to another pan is not a easy fix. Other than the two small depressions my pan is about as good as a person can find.
So I have a plan, let me know what everyone thinks......
I plan on cleaning the pan up very well, put it back on the pan jig and straighten anything that may have been bent during the install and remove process. Things like bolt holes being bent is about all I see that may need fixed. After it is back as straight as I can get it on the pan jig. I plan on sitting the pan in my roll around engine stand to make it easy to work on. Then I plan on installing both sides of the hogs head gaskets to the bare oil pan sitting on the engine stand. I will use the black Permatex right stuff (ultra black) as my sealer. I will use plenty of it. At the dip I will use too much, so it squeezes out both sides of the gasket. I will only use the sealer on the oil pan side of the gasket, making sure the top side is clean. Then I will set the hogs head in place and install all of the bolts and nuts. Then I will lightly snug the bolts down using only a screwdriver style nut driver, being very careful to pull it down slowly and evenly. . Using the hogs head this way should act as a press to push the gasket into a level and straight fit. After The sealer dries, I will remove the hogs head and using a razor knife clean up all the excess squeezed out sealer from the inside of the pan. Then I can proceed to installing the pan and hogs head to the engine in a normal way. Im hoping that this procedure will give me a good seal at the pan arms.
Any input will be appreciated....
The pictures below were taken before I scraped and cleaned the depression area, and tested it with a straight edge. I forgot to take pictures of the cleaned up area, but these photos show the problem better than a cleaned up area would.....
