I want one.......
Topic author - Posts: 663
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I want one.......
I was looking thru the instructions on how to post pictures and found this.
Now that would be GREAT on the front of the Speedster, I want one
There are a couple of things about it that look a little odd. It seems to have an eight cylinder distributor, a water pump and an oil pump. Wow that would be fun but would the water pump get me banned from various speedster run?
Tony Bowker
La Mesa, California
La Mesa, California
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: I want one.......
I run a similar odd 8 plug distributor ! ZOOM - ZOOM !
When is the tour, Tony ?
- First Name: Walt
- Last Name: Berdan
- MTFCA Number: 16421
Tony, You would need to check with the event organizer or the posted rules for any of the speedster events. Some have been strict about no post '27 equipment in the past but may be more flexible now. Rules do vary some between the various groups as is their privilege. At one time in at least one group that distributor would not have been permitted but the water pump would have been as that appears to be an appropriate T era accessory front cover.
- First Name: Walt
- Last Name: Berdan
On second observation, the distributor on your photo might actually be early enough to qualify. My first look had me thinking it was a Nissan part like Steve and others have.
- First Name: Chad
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
It's a period front plate and totally allowed as far as I know. Now good luck finding one . . .
- Last Name: McEnhill
- MTFCA Number: 50298
I like the NASA sticker on a Model T!
Still looking for the 1,000 square foot house with the 12 car garage...
- First Name: Chad
For those wondering it is a green plate, more information can be found here.
http://www.mtfca.com/discus/messages/82 ... 1545458635
- Last Name: Codman
The first T that I soloed in had a VW distributor. My T has a magneto as God and Henry Ford intended.
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
This Green Engineering triple plate is a NOS era accessory. The distributor is a Delco Studebaker reworked to fire 2 plugs at once. Complete triple plates are a hard item to find, Green Engineering equipment is darn near impossible.
- First Name: Bob
- Last Name: Bishop
- * REQUIRED* Type and Year of Model Ts owned: 1914 touring, 1917 touring
- MTFCA Number: 502
Tony,
The water pump would probably get you banned from the Model T Club!
Bob Bishop
San Diego, CA
San Diego, CA
- First Name: Les
- Last Name: Schubert
I see the Nissan cap is referred to, and that is currently a readily available option. I adapted one to a Bosch front plate distributor. A viable way to fire dual plugs using this cap is a coil for a two cylinder Onan engine. It fires both plugs every time in its original application and seems to work ok firing the Nissan dual plug distributor cap
- First Name: Les
The cap and rotor adapter was not difficult to make
