A part found- what is it?
Topic author - Posts: 302
- First Name: Bill
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
- MTFCA Number: 22487
- MTFCI Number: 17887
A friend found this small brass looking plaque and I thought someone on the forum might know it's source. His description: "The size can be estimated by the size of the quarter. It’s about 1/8 inch thick, and the it looks like the back side has a coating of solder on it."
Does anyone know this part's original usage?
- Attachments
- unknown logo.jpg (15.49 KiB) Viewed 3642 times
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Re: A part found- what is it?
I'm pretty sure it is a Model A Ford radiator shell emblem
- Last Name: Clements
- MTFCA Number: 49592
It looks like the hood emblem from an 8N Ford tractor.
- First Name: Bill
Charles says the badge appears to be copper.
- Last Name: in Tennessee
- * REQUIRED* Type and Year of Model Ts owned: '23 Cuttoff
I thought the Model A radiator shell emblems were steel with blue porcelain - except 31 which were painted I think. But still steel.
If Model A it should be 2 31/32 wide and 1 15/32 tall. Or so I think.
I vote for 8N or 9N emblem.
Now you just need a tractor to go with it, but make sure you get a PTO clutch when you hook the bush hog up to it!!!
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Looks like a tractor badge minus the chrome plating.
- First Name: Erik
- Last Name: Johnson
It's a Model A badge.
It's spent a long time in the ground.
The blue cloisonne (porcelain) is gone.
They were nickel or chrome plated over copper or brass. You can see evidence of this on my example where the porcelain is chipped.
The solder on the back is for the stud.
- First Name: Erik
Here is a 1932-35 Ford truck badge.
Note the copper/brass where the cloisonne is missing.
- First Name: Bill
Thanks friends! I think he tends to agree with you.
Bill
Bill
