A part found- what is it?
Posted: Thu Jun 11, 2020 10:30 pm
by Bill Robinson
A friend found this small brass looking plaque and I thought someone on the forum might know it's source. His description: "The size can be estimated by the size of the quarter. It’s about 1/8 inch thick, and the it looks like the back side has a coating of solder on it."
Does anyone know this part's original usage?
Re: A part found- what is it?
Posted: Thu Jun 11, 2020 10:49 pm
by dobro1956
I'm pretty sure it is a Model A Ford radiator shell emblem
Posted: Fri Jun 12, 2020 12:49 am
by Scott C.
It looks like the hood emblem from an 8N Ford tractor.
Posted: Fri Jun 12, 2020 9:21 am
by Bill Robinson
Charles says the badge appears to be copper.
Posted: Fri Jun 12, 2020 10:32 am
by SteveTN
I thought the Model A radiator shell emblems were steel with blue porcelain - except 31 which were painted I think. But still steel.
If Model A it should be 2 31/32 wide and 1 15/32 tall. Or so I think.
I vote for 8N or 9N emblem.
Now you just need a tractor to go with it, but make sure you get a PTO clutch when you hook the bush hog up to it!!!
Posted: Fri Jun 12, 2020 10:41 am
by Humblej
Looks like a tractor badge minus the chrome plating.
Posted: Fri Jun 12, 2020 10:49 am
by Erik Johnson
It's a Model A badge.
It's spent a long time in the ground.
The blue cloisonne (porcelain) is gone.
They were nickel or chrome plated over copper or brass. You can see evidence of this on my example where the porcelain is chipped.
The solder on the back is for the stud.
Posted: Fri Jun 12, 2020 10:51 am
by Erik Johnson
Here is a 1932-35 Ford truck badge.
Note the copper/brass where the cloisonne is missing.
Posted: Fri Jun 12, 2020 5:03 pm
by Bill Robinson
Thanks friends! I think he tends to agree with you.
Bill
