Is this safe to run?
Posted: Fri Jun 26, 2020 9:33 pm
by Larry e rutt
I put a new fan blade on and the flange crumbled in my hand.. what remained seamed strong. My question is do u think this will last a while yet ?
Re: Is this safe to run?
Posted: Fri Jun 26, 2020 9:34 pm
by Larry e rutt
Whoops I need to add the pic[image][/image]
Posted: Fri Jun 26, 2020 9:36 pm
by Larry e rutt
Wow try this again
Posted: Fri Jun 26, 2020 9:37 pm
by tdump
Without seeing it,I would say it is not.Remember that fan is going to try to drill a BIG hole in your radiator if it gets loose.
Posted: Fri Jun 26, 2020 9:42 pm
by Larry e rutt
[image][/image]Ok I'm struggling here
Posted: Fri Jun 26, 2020 9:44 pm
by Larry e rutt
Sorry my phone is not cooperating
Posted: Fri Jun 26, 2020 10:11 pm
by Humblej
No, run without a fan until you can find a replacement, they are plentiful and cheap. Unless you are in a parade or stuck in a traffic jam, you do not really need a fan.
Posted: Fri Jun 26, 2020 10:27 pm
by Scott_Conger
https://www.modeltford.com/item/3004E.aspx
15% the price of a new radiator, or equivalent to 4 1/2 fill-ups in PA.
piece of mind: priceless
Posted: Sat Jun 27, 2020 7:21 am
by Larry e rutt
Ok.. thanks
Posted: Sat Jun 27, 2020 7:55 am
by Humblej
Larry, while you are in there you should re-route your timer wiring harness up to the water outlet and back. Use an adell clamp at the water outlet bolt to hold it just like Henry did.
Posted: Sun Jun 28, 2020 10:45 am
by Mark Gregush
Wondering too about the routing of the timer wire harness? The 26/27 with coil box on the motor would have had a short harness that ran from the box over the engine down the passenger side to the timer. Cars and trucks with firewall mounted coil boxes, the timer harness would have been all on the passenger side along the frame rail. With it running along the front like that and loose, potential to cut with fan belt or? If it is the correct 26/27 harness, move it so it goes over the top of the water outlet. There would have been a wire clip that held it using the passenger side water outlet bolt.
Posted: Sun Jun 28, 2020 10:52 am
by John kuehn
Running without a fan is only as good as your radiator.
Posted: Sun Jun 28, 2020 10:55 am
by RajoRacer
Are you referring to the aluminum fan hub flange that crumbled ?
Posted: Sun Jun 28, 2020 11:11 am
by Mark Gregush
Adjuster, but the pulley does look a little wonky, could be the angle.
Posted: Sun Jun 28, 2020 11:41 am
by RajoRacer
Thanks Mark - and, I had my glasses on !
Larry - I have some of those eccentrics around here if you want to replace it.
Posted: Sun Jun 28, 2020 8:02 pm
by RajoRacer
Larry - I sent you an email w/photo - check your junk mail foder.
by RajoRacer
"Folder" !!!
Posted: Sun Jun 28, 2020 9:18 pm
by 2nighthawks
....it's O.K. Steve,....sometimes dar's foder in dem' folders! :D
Posted: Mon Jun 29, 2020 7:41 am
by Larry e rutt
Sorry my email changed... try... larryrutt7at gmail.com
