I was putting the shiny stuff back on my early 14 and came across this
All 4 pins on both cowl lamps are the same.
They are FORD victor Model 2 lamps
Now what??
1914 Cowl lamp issue. How to fix this?
Topic author - Posts: 77
- First Name: Bill
- Last Name: Dodd
- * REQUIRED* Type and Year of Model Ts owned: 14 T Touring
- MTFCA Number: 27186
14 Touring
- Last Name: Stroud
- Board Member Since: 2011
Re: 1914 Cowl lamp issue. How to fix this?
I'd be willing to bet Rich Eagle could figure out something. Sorry Rich, I don't mean to add anything more to your project thoughts. Dave
1925 mostly original coupe.
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Cut it off, drill it out get a piece of brazing rod and solder it in place. I went a bit longer on mine and filed it to fit. Wasn’t very difficult but in took two tries before I was happy.
- MTFCA Number: 1219
Thanks David. I think Mark has a good fix. I've never had to but sounds like it would work fine. A soldering iron would be better than an open flame if there are kerosene fumes inside.
- First Name: Bill
- Last Name: Dodd
Thanks, I didnt think of brazing rod. Now to give myself a refresher course on planning carefully.
14 Touring
