Babbitt Question
Posted: Mon Jun 29, 2020 10:25 am
So I dove into an engine/transmission I recently brought home. I found cylinders 1, 3, and 4 have no Babbitt left at the rod caps, resulting in a lot of play. The inside if the block is glistening with silver flakes.... The caps are all cotter pinned, so i dont think someone slapped an engine together with unserviceable parts.
The mains are tight and show no signs of visible issues. I will open the caps today and see.
My question is this.... if the mains check ok, and the crankshaft is not cracked, can I just do new babbitted rods and caps ? I'll probably do pistons and rings too. Will an engine have an abrupt failure like this due to lack of oil?
Thanks for the help!
