Clean brake shoe/Lining
Posted: Mon Jun 29, 2020 9:30 pm
by Ben Umberger
Is there any way to reasonably clean the break shoe and lining?
What would you use to clean the inside of the drum?
Ben
Re: Clean brake shoe/Lining
Posted: Mon Jun 29, 2020 9:33 pm
by Dallas Landers
I soaked and scrubbed shoes in gas. Used brake cleaner to finish. Same with drums to get all the sticky gunk off while rebuilding the rear axle on my 26 RPU.
Posted: Mon Jun 29, 2020 10:57 pm
by Ben Umberger
I'll try that overnight
Posted: Tue Jun 30, 2020 12:36 am
by DHort
Kerosene. Less flammable.
Posted: Tue Jun 30, 2020 3:20 am
by NoelChico
I've used E-85 as it's 60-85% ethyl alcohol, not as flammable (I presume) as gasoline, and it's cheap. when tossed out and lit, it burns with a much less intense flame than gasoline. Just my opinion, however
Posted: Tue Jun 30, 2020 9:49 am
by jiminbartow
I have always been taught to never use gasoline as a soaking/cleaning agent. It is just too flammable and dangerous and the fumes go very far. If the fumes happen to find an ignition source, such as the pilot light of a floor mounted water heater, it can ruin your day, if not your life. As a solvent for cleaning oil based deposits from parts, I have found nothing better than lacquer thinner but it is a hot solvent and should not be used to clean painted parts unless you want to remove the paint. When soaking in any kind of flammable solvent, it is always a good idea to cover the container to keep the fumes and solvent contained. To keep your wife happy, instead of using your wife’s cooking pots for cleaning parts, you can find very nice sets of stainless steel parts cleaning containers in various sizes in the form of cooking pot sets, with form fitting tops at Walmart. You’ll be surprised at how much you use them around your shop. Jim Patrick
Posted: Tue Jun 30, 2020 11:06 am
by RajoRacer
That's why they make Brakleen !
Posted: Tue Jun 30, 2020 11:20 am
by critterpainter
As a last step in de-greasing use Super Clean or Purple Power or a cleaner of that sort. It Will remove all traces of oils left by other cleaners or gasoline.
Posted: Tue Jun 30, 2020 12:02 pm
by Dallas Landers
I should have noted to clean parts with gasoline " OUTSIDE". Brake clean after. A good scrub with Dawn dishsoap would probably work also.
Posted: Tue Jun 30, 2020 3:46 pm
by Virtus
BMW in Europe sell an aerosol brake cleaner. I used it recently on my TT rear shoes and drum. Best cleaner I have used, I thought the shoes were beyond redemption. Would highly recommend.
Posted: Tue Jun 30, 2020 4:18 pm
by HPetrino
Whatever you use, be SURE to wear gloves designed for that purpose! Any of the products you're likely to use are quite toxic and it's best to avoid direct contact with your skin.
Posted: Tue Jun 30, 2020 4:39 pm
by Mustang1964s
My go to is LA's Awesome Cleaner - 20 oz - Dollar General.
I put it in a plastic container with lid. Let it soak over night. Pull the part. Scrub with wire brush, rinse and repeat.
