Weaver Model E Tire machine
Topic author - Posts: 310
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
Wondering who is using one?, I am also looking for the dimensions for the bead breaker handle spring, was broke when It was given to me 57 years ago. Thanks George
- First Name: William
- Last Name: May
Re: Weaver Model E Tire machine
I found the patent drawings at a site known as "Castle Equipment".
Apparently they were the successor company, but they seem to have made a real effort to show their earlier "Weaver" equipment. They even have a section on the correct colors for early "Weaver" equipment.
I think the patent drawings would be of limited help, EXCEPT they must show how the device actually works, so you should be able to put all the parts in relative position, and determine, at least to start with, how long or short something should be. You may have to experiment a little, but if you cannot find a manual, it would be the next best thing. I'd get some thin mild steel bar (1/8" thick or so) and trial fit until I was ready to try for an actual replacement part, which is when I would go to the heavy original steel thicknesses, etc.
That looks like a very nice machine. All the Weaver stuff seems pretty tough and heavy duty. They show a "Tire Spreader Machine" to open up tires for rubber repair patches on the interior, and that machine should scare the leak right out of the tire that is rolled up to it. When it's applied, you have a working area for your tire patch work that is the size of a dinner plate!
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
I believe Adam Doleshal has a Weaver, but I do not know what model it is. Works great on clinchers.
- First Name: Philip
- Last Name: Jamison
My spring measures 8" long total, made of two straight pieces with round bends at each end. The coiled part (22 coils) is 2.75". The spring steel is .108"D. The top part (straight with a hook) is 3.5" long. The hooks are face opposite directions. Attached is a sketch.
Phil
Phil
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
- MTFCA Number: 443
- MTFCI Number: 23136
Website mentioned above, I have a floor weaver floor jack.
http://www.castleequipment.com/Jacks/PA ... _Parts.htm
http://www.castleequipment.com/Museum/h ... turing.htm
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
- Last Name: Hand
Philip Jamison, Thank you for looking at your machine & giving me the information on what size that spring should be. Now I am on a spring hunt, it works fine but I feel it would be easier with out the lever flopping around. Thanks again George
