Can arc welding weaken magnets ?
Posted: Tue Jul 14, 2020 2:41 am
by Roffe
I am wondering about arc welding(DC) can hurt the magnets. I'm about to do a small repair on the frame close to the engine,
and would like to hear your opinion. Thanks.
Re: Can arc welding weaken magnets ?
Posted: Tue Jul 14, 2020 3:23 am
by Kerry
Actually it would be around the other way, if welding to close to something that is magnetized, it stuffs up the weld, Called magnetic arc.
Posted: Tue Jul 14, 2020 3:40 am
by Roffe
Thanks Frank. I've read about that phenomenon but its about 3 feet from the transmission so I don't think that will be a problem.
I am more concerned with the current flowing thru the frame/engine. But Im maybe overthinking the possible danger of demagnetising . ;)
Posted: Tue Jul 14, 2020 3:53 am
by Kerry
Just make sure that your earth clamp is next to your weld area and all will be good.
Posted: Tue Jul 14, 2020 3:57 am
by Roffe
Thanks. Good advise.
Posted: Tue Jul 14, 2020 10:59 am
I welded up a crack in the frame and put on a reinforcement right at the place where the crankcase ear is bolted to the frame. That was almost 30 years ago and the frame has not cracked again and the magneto still works.
Posted: Tue Jul 14, 2020 5:19 pm
by Roffe
Norman, that's a relief to hear. Thank you.
