Ever seen one of these broken
Cambin
First Name: Cameron
Last Name: Smythe
* REQUIRED* Type and Year of Model Ts owned: 1925 Duncan and Fraser 1/2 ton pickup and a 1922 Sydney built steenbhoms tourer
Post by Cambin » Fri Feb 15, 2019 10:30 pm
[image][image][/image][/image]has anyone come across this type of breakage and if so what are the causes?
The pin was solid so it wasn’t a loose pin
Don Conklin
First Name: Donald
Last Name: Conklin
* REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1923 depot hack, 1927 speedster
MTFCI Number: 10087
Re: Ever seen one of these broken
Post by Don Conklin » Fri Feb 15, 2019 10:55 pm
Torque tube not modified to accomodate a ball bearing 4th main
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Feb 15, 2019 10:58 pm
No but I have had one with the T-tube broke inside the casting at the other end. The radius rods kept it in place locked at the rivets where it had sheared.
1920 Dodge touring
Cambin
First Name: Cameron
Last Name: Smythe
Post by Cambin » Sat Feb 16, 2019 1:04 am
No mods all original
No pin gouge
And radius rods look good
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
MTFCA Number: 11598
Post by kmatt » Sat Feb 16, 2019 1:27 am
If the rear spring center bolt head broke or slipped out of the rear cross member and the rear axle, spring and all, shifted slightly it could have stressed the torque tube over time. Because the torque tube ball is held fast by the motor even a slight and unnoticed misalignment could stress the torque tube in the area that broke.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sat Feb 16, 2019 8:22 am
Too many burnouts! :o
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Sat Feb 16, 2019 10:41 am
I didn't see any grease cups.....
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Post by Howard Tomlinson » Sat Feb 16, 2019 11:26 am
I haven't seen one broken, but I did take one housing apart where the universal pin evidently had backed out and scored the inside of the housing. Being that that area is already pretty thin a similar break could have happened.
Altair
First Name: David
Last Name: Menzies
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring and 1915 Touring both Canadian models
MTFCA Number: 27825
Board Member Since: 2012
Post by Altair » Sun Feb 17, 2019 12:03 am
Just throwing out a thought, the break in that location would be developed by engine torque, the bolts that sandwich the rear part of the torque tube to the diff housing are 3/8" + 1/32 or 13/32" they are referred to as special bolts, if they were ever replaced with incorrect 3/8" bolts this could allow unwanted movement, just a thought.
Jem
First Name: Jem
Last Name: Bowkett
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Post by Jem » Sun Feb 17, 2019 2:31 am
The nose of the torque tube is free to move around in the ball cap to accommodate suspension movement. If that cap is dry or seized for some other reason, something has got to give.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Sun Feb 17, 2019 3:26 pm
Were you using a shim to take up for wear in the ball/retaining ring? Too much shim can lock up the ball joint and may cause this.
