Valve Stem
Topic author - Posts: 180
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
- MTFCA Number: 16688
- MTFCI Number: 19356
Valve Stem
I just had a flat on the R F wheel. Upon opening the tire I found that the brass valve stem broke loose from the inner tube. Can a new stem be attached to the tube?
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: Valve Stem
That depends on the hole in the tube. If it is not torn you can simply reinstall your valve. If a new tube is needed I highly recommend those made by Blockley, https://www.blockleytyre.com/product/30x3-5-inner-tube
- Last Name: Saylor
- MTFCA Number: 1695
- MTFCI Number: 23870
Re: Valve Stem
Hal, Try a metal valve stem. Steve spells it out here.
http://dauntlessgeezer.com/DG110.html
- First Name: Rich
- Last Name: Bingham
Re: Valve Stem
The tube shown in the Blockley site has a brass stem.
So far, the 30x3” tires and tubes don’t seem to be available yet.
"Get a horse !"
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Valve Stem
I'm sure the metal stem tubes from Blockley are excellent. But I have been buying Hartford tubes, cutting off the rubber stems, and installing my own metal stems. So far they have presented no problems. I intend for my next tyres to be Blockleys, but I will keep the Hartford tubes in them.
