Bench Top Rear Axle Holder
Posted: Sun Jul 26, 2020 12:58 pm
by dang.1922
I am getting ready to start disassembly on the rear end in our 1921 T. I would like to know the size of the hole in the bench top axle holder as I am going to make one. Thank You for any help. ----Dan Greger
Re: Bench Top Rear Axle Holder
Posted: Sun Jul 26, 2020 1:33 pm
by CudaMan
The hole in mine is 6 1/4 inches in diameter. I made mine out of a scrap 2x10 I had laying around.
Posted: Sun Jul 26, 2020 2:32 pm
by DanTreace
Bevel that hole some, fits snug that way. Put a reminder note on mine
Posted: Sun Jul 26, 2020 6:17 pm
by TRDxB2
I set mine up on my power miter box stand. That way I could move take it down and store it when done.
Made a cradle to keep the torque tube from moving around
Posted: Mon Jul 27, 2020 6:28 am
by dang.1922
Thank You all for the reply's, this helps a lot. Now it is time for the interesting part to just see how bad it is inside, when I sucked some oil out of the fill hole it had a lot of Babbitt in it. ---Dan
Posted: Mon Jul 27, 2020 10:35 am
by StanHowe
While you're at it, take an old ring gear and bolt it down with the teeth up.
I cut a hole in my bench top but you can also just bolt it over the edge of your bench.
Handy as a pocket in a shirt for holding the assembly, removing ring bolts etc, tightening them etc etc.
