Trick to removing radiator mount bolts
jakerake1
First Name: Don
Last Name: Germain
MTFCA Number: 51123
Post by jakerake1 » Thu Jul 30, 2020 5:38 pm
OK folks;
I guess I am not holding my mouth quiet right while attempting to remove the radiator mount bolts for my 1916 Run About.
HELP!
MTFCA Number: 28924
Re: Trick to removing radiator mount bolts
Post by John kuehn » Thu Jul 30, 2020 6:09 pm
Get you a screwdriver or something that will wedge between the frame and the bottom nut and then try to remove the top nut. I’ve also used a chisel that worked just right before that wedged pretty tight.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Thu Jul 30, 2020 6:27 pm
When working with any of the cotter pinned nuts on my T, it typically demands a small blood sacrifice...usually from one of my fingers.
After that, it’s happy to oblige.
1924 Touring
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Thu Jul 30, 2020 7:12 pm
What these guys said. The brass-era radiator stud nut is considerably shorter than the black-era (1917 and later) ones. The early, short one can spin merrily around while you drive yourself batty (or in my case, battier) trying to get the stud out. The longer one will jam against the frame when turned, so when you follow the advice here and finally get your studs out, you may want to install the later, longer type nut when you go to put them back. While it would not be correct, it may save your sanity next time the studs need to come out.
jakerake1
First Name: Don
Last Name: Germain
MTFCA Number: 51123
Post by jakerake1 » Thu Jul 30, 2020 8:12 pm
As always. Thanks guys for the direction...
Don
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Thu Jul 30, 2020 8:44 pm
Ain't THAT the truth!! Seems every time I go out to do something, the main benefactor is Band-Aid brands... :lol:
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Thu Jul 30, 2020 9:31 pm
. . . The longer one will jam against the frame when turned, so when you follow the advice here and finally get your studs out, you may want to install the later, longer type nut . . .
While that’s true, if you have the original “thick headed” fender brace bolts, the longer stud nut won’t allow the stud to sit vertically, which causes the springs to bind, and a fair amount of gripes mounting the radiator properly. Someone had installed the “new” longer nuts on my ‘13, I had to cut them down to get my radiator to mount without a bind. YMMV :D
"Get a horse !"
jakerake1
First Name: Don
Last Name: Germain
MTFCA Number: 51123
Post by jakerake1 » Fri Jul 31, 2020 8:54 am
Thanks all for your valuable input. Was able to finally remove the beast... LOL
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Jul 31, 2020 11:17 am
OK, Rich; now you made a little dim bulb go off in what's left of my mind. I seem to recall, sorta, that I used the later nut on my '14 but shortened it a bit to clear the bolt heads in an attempt to get the best of both worlds. That was almost 20 years ago so I don't recall much, but I bet it happened that way.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Jul 31, 2020 11:26 am
First of all, what the author is trying to talk about is a stud, not a bolt. And yes, we've all had that problem.
