Remove Pinion Gear with U-joint still on?
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Mon Aug 03, 2020 12:43 am
Is there a way of removing the pinion edit:**gear** without taking the U-joint off? The drive shaft and tube are off the differential but as far as I know I am unable to fit a puller jaws onto it not enough room and the slam it on a piece of wood maneuver isn't going to work because the U-joint will prevent the slide hammer action of the tube. Is there a way to get it off under these circumstances?
Re: Remove pinion nut with U-joint still on?
Post by Allan » Mon Aug 03, 2020 2:36 am
Ignatio, if you have a second U joint of any condition, put it onto the mounted joint and hold the square end in a vice. That way the driveshaft is held captive and you can use whatever wrench to undo the pinion nut.
Hope this helps,
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Aug 03, 2020 9:36 am
Why not remove the U-joint?
Last Name: House
MTFCA Number: 115
Post by George House » Mon Aug 03, 2020 10:47 am
Pardon my ignorance Allan (people have to do that all the time) but why the need of a second U Joint ? I’ve placed the attached U Joint square end in a vise and supported the shaft and tube then used whatever wrench
george from up over
jab35
Last Name: Bartsch
MTFCA Number: 30615
Post by jab35 » Mon Aug 03, 2020 11:06 am
In the OP, " I am unable to fit a puller jaws onto it not enough room" suggests difficulty pulling the pinion. I'm curious how that might be accomplished. Never tried that without first removing u-joint and drive tube. regards, jb
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Mon Aug 03, 2020 12:09 pm
Place the square u joint end in one jaw of your Dixie Service Station Equipment axle stand and tighten the jaw to hold the drive shaft. Let the DS tube rest in other jaw of said stand, tighten to hold tube steady.
This will let you remove split pin on pinion nut and remove said nut.
Then slide DS out of tube.
Then you can remove u joint.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Aug 03, 2020 12:29 pm
...your Dixie Service Station Equipment axle stand...
SMILING PIG.jpg (55.82 KiB) Viewed 4248 times
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Mon Aug 03, 2020 1:08 pm
I guess you could use a KRW stand. I like the Dixie stand because you can fold up the support so it is out of the way.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Mon Aug 03, 2020 1:42 pm
Egads I mispoke. The pinion nut is off, the pinion GEAR I meant to say is what I want off. I don't want to take the U-joint off because this differential doesn't belong to me and it has to go back to the owner and I would rather leave the U-joint on if I can get away with it.
Is there a way of removing the pinion nut without taking the U-joint off? The drive shaft and tube are off the differential but as far as I know I am unable to fit a puller jaws onto it not enough room and the slam it on a piece of wood maneuver isn't going to work because the U-joint will prevent the slide hammer action of the tube. Is there a way to get it off under these circumstances?
Re: Remove Pinion Gear with U-joint still on?
Post by Norman Kling » Mon Aug 03, 2020 2:12 pm
Is something wrong with the gear or bearing? Otherwise why do you want to remove the gear?
A regular puller should fit behind the gear with a screw to tighten the puller. Not the sliding hammer type puller. Once the gear starts to move it should come right off because the shaft is tapered It is quite similar to pulling a rear wheel hub.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Mon Aug 03, 2020 2:18 pm
That is easier. Go over to your Stevens Rear axle Tool wooden case and get out the Stevens Pinion Gear puller. Job done.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Aug 03, 2020 2:52 pm
Now if you don’t have all the fancy era tools to do this then I would use my “bearing splitter puller”(available at better tool stores). It is a puller that you will get enough use of to justify the cost.
GrandpaFord
First Name: Neil
Last Name: Kaminar
MTFCI Number: 22425
Post by GrandpaFord » Mon Aug 03, 2020 3:50 pm
I have been known to take a grinder to the jaws of a puller to get them to work on difficult to pull items.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Mon Aug 03, 2020 7:31 pm
The goal was to take a 11 tooth pinion gear off one assembled drive shaft and tube and put it on another drive shaft that was disassembled. The other was a standard 10 tooth pinion. I used a 3 jaw puller and a impact to take off the standard 10 tooth un-assembled. The basketball goal base it is resting on is optional.
The second one I used the Steve Jelf and others bang it on a piece of wood method. See picture forensic. There are 3 impressions in the wood. Impression 1 is the greasy nut resting on the wood before banging. Impression 2 is the first hard bang on the piece of wood with the pinion gear staying put. Impression 3 in the middle is the second bang on the piece of wood with the pinion gear impressions showing that it has now come loose. Ta da!
-- IV
Post by Allan » Tue Aug 04, 2020 12:28 am
George, I use a second U joint to overcome the vice offset at the edge of my bench. It allows me to swing the tube and driveshaft around onto the bench so I don't have to arrange extra support. Each to his own I guess.
