Fan pulley shaft problem
Posted: Fri Aug 07, 2020 6:21 pm
by BarryB
This is probably a dumb newbie problem...I have a 26 roadster and am replacing the fan pulley shaft. When I tighten the shaft nut, the pulley won't spin and if I loosen the nut til the pulley spins it has a lot of wobble and then just tightens up. What am I doing wrong?? Thanks!
Re: Fan pulley shaft problem
Posted: Fri Aug 07, 2020 6:30 pm
by Henry K. Lee
Over the years your stop shoulder on the bolt shank is probably gone or the cam washer has been crushed. You can either hold the back of the shaft by a flat spot and then tighten the nut. Best to add a star washer to prevent it from coming loose.
Hope this Helps,
Posted: Fri Aug 07, 2020 6:42 pm
by jab35
Barry: This might help. app.php/gallery/image/1124
Posted: Fri Aug 07, 2020 8:47 pm
Barry, the step in the shaft is meant to screw into the holder up to the step. The nut on the end is then just a locknut. If your fan is binding with the new shaft, the face on the bushings needs to be sanded/filed back somewhat to get clearance for the fan.
Hope this helps,
Posted: Fri Aug 07, 2020 8:50 pm
by Henry K. Lee
Dah on me.., Thanks Allan! My allergies got me so jacked up at the moment!
Posted: Sat Aug 08, 2020 12:11 pm
Were the bushings replaced or just the shaft? If the bushings were not, then you now have a new shaft in a worn hole.
