Kingston 5 Ball for 1909
Topic author - Posts: 979
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
I posted a couple pics of the new caps for this a week or two ago, thought I post a pic or two of it done and off to the owner. It had been whacked with a wrench, a hammer and whatever else, lotsa bruises that hadn't healed on their own, took a little massage to get it looking good.
There is always some controversy over the air inlet tube and design. This is how it came in except the hat was squished flat. This is how it goes out. Right or wrong, correct or not, it went away.
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Re: Kingston 5 Ball for 1909
Splendid! Nice Work Stan!
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
Like most men, fancy diamonds and jewelry don't excite me much. But a perfectly cleaned up and operational brass carburetor ? Now, that really turns my crank !
Bravo, Stan !
Bravo, Stan !
- First Name: R.V.
- Last Name: Anderson
Well if that works half as good as it looks....
- MTFCA Number: 1219
It is always a treat to see things we will never have or clean up that nicely.
I feel I owe something to just look at it but......
I'm perpetually in awe of you accomplishments.
- Last Name: House
- MTFCA Number: 115
....should be in the Smithsonian with all the other national treasures. Gorgeous work Stan !!
- First Name: Martynn
- Last Name: Vowell
- MTFCA Number: 9908
- Board Member Since: 2012
Stan...does it have some other designation other than 1909, Kingston 5 ball? Anything different about it other than the air intake?
Fun never quits!
- First Name: Stan
- Last Name: Howe
Not that I know of. The air intake varies from year to year but the body of the carb is the same as near as I can tell. The later ones also added a butterfly choke but that is also part of the air intake.
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
So how does the 5 ball compare to later Kingston's as far as performance?
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
The mushroom seems to be always missing, they must of vibrated off in the day.
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910, two1911, 1913 Tourings
- MTFCA Number: 52262
I have ran a Five Ball for over twenty years on my 1910 and 1911 and have worked well for me. Rebuilt them with a Brass float and new needle and seat.
- First Name: Stan
- Last Name: Howe
I was using a brass float but have some new synthetic material I like better which can be shaped like the original cork float.
I make a needle of my own design that uses the original seat. I do not like drilling out the original seat to put a modern type seat in.
Most of those do not pull the needle open as this design does.
But there are lots of ways to do it, mine is just one way.
