Pinion Bearing question
Posted: Sat Aug 15, 2020 6:41 pm
by Mountainrider
I have the drive shaft ready for assembly. Before I do final assembly a question, the bearings sleeve is 3 1/16 but my bearing is only 2 7/8. 3/16 of play on the sleeve is correct. Don’t want to start tightening things up and set end play in not.
Re: Pinion Bearing question
Posted: Sun Aug 16, 2020 6:48 am
by Mountainrider
I should have wrote, is the 3/16 of play For the roller bearing to move back and forth between pinion gear and thrust bearings correct?
Posted: Sun Aug 16, 2020 6:59 am
by Joe Bell
The Hyatt bearing should be able to float, drive shaft should stay still on end play in the tube.
Posted: Sun Aug 16, 2020 7:26 am
by Mountainrider
Thank you.
