Facing rode
Posted: Mon Feb 18, 2019 12:37 pm
by D.Yoder
I made a new fixture for more accurate machining rods face.
Re: Facing rode
Posted: Mon Feb 18, 2019 1:10 pm
Facing the rod is better than facing the music. :)
Re: Facing rode
Posted: Mon Feb 18, 2019 1:26 pm
by DLodge
Or sparing the rod and running the risk of spoiling the child. :D
Re: Facing rode
Posted: Mon Feb 18, 2019 1:35 pm
by Rich Bingham
Spare rods is a good idea . . .
Re: Facing rode
Posted: Mon Feb 18, 2019 1:53 pm
by RustyFords
Neat.
Re: Facing rode
Posted: Mon Feb 18, 2019 6:31 pm
Dean, do you not face the rods and caps as a pair?
Re: Facing rode
Posted: Mon Feb 18, 2019 7:47 pm
by D.Yoder
Allan, I am trying facing indexing on the rod bolt holes. More work but I think more accurate.
Re: Facing rode
Posted: Mon Feb 18, 2019 10:40 pm
Dean, I presume your fixture will allow you to perform the same machining on the rod. I would be interested to know how the two match up after separate operations. A very handy old time garage owner I had the pleasure of finding some T bits for made a fixture to hold an assembled rod to a faceplate in his lathe. He'd bore the rod and chamfer/face one side in one setting, then turn the rod to machine the width and the second chamfer. My lathe is not big enough to swing a rod, or I would have a go at it.
Re: Facing rode
Posted: Tue Feb 19, 2019 11:16 am
by D.Yoder
Allan, The rod and cap mate up perfectly . I set my jig for 1.490 because if the rod bolt is not perfectly perpendicular to the mating surface of the rod and cap it changes the thrust thickness. Ford specks are 1.480-1.490
