Haven't posted on my project in a while. I just got more pieces this past weekend.
The running gear after I jacked it up and put four replacement wheels on it. The original wheels were rotted through.
The engine didn't turn when I got it, now it does. I oiled the bores and with a 2 x 4 scrap, I lightly tapped each piston using a 2 pound hammer
parts you don't see are 5 demountable rims that need blasting and coating.
1922 Center Door project
Topic author - Posts: 813
- First Name: William
- Last Name: Vanderburg
- MTFCA Number: 28382
Last edited by Will_Vanderburg on Sun Aug 23, 2020 7:10 pm, edited 1 time in total.
William L Vanderburg
1922 Center Door Sedan
Re: 1922 Center Door project
Hub replacement
hub had a retrofitted Chevrolet cap
The frame had an Ames horn on it. Stored under a plastic tub for I don't know how long. I don't even know if it works. Been raining on and off today and the place where I can test it is kind of cramped at the moment.
horn cap interior as found
horn interior as found
Looking good W V !
- Last Name: Warren
Great start, keep us posted. Thanks for sharing. jw
I took the horn outside and hooked it up to my Touring. It WORKS....
