Do new coil points need to be prepped?
Posted: Wed Sep 09, 2020 10:44 pm
by DHort
When I receive new points from a vendor do they need to be cleaned in any way or prepped in any way before they are installed?
Re: Do new coil points need to be prepped?
Posted: Thu Sep 10, 2020 12:45 am
by jab35
I always clean the contacts with alcohol or carb cleaner, something that was recommended here on the forum a number of years ago. jb
Posted: Thu Sep 10, 2020 1:26 am
I soak them in lacquer thinners to remove any preservative/lubricant from them, paying particular attention to the points and the cushion spring. The cushion spring action needs checking, and the rivet attended to to set the spring. Then they are good to go. Make sure the points are correctly aligned once they are installed.
Hope this helps,
Allan frrom down under.
Posted: Thu Sep 10, 2020 10:43 am
by Adam
Ask the vendor and then post their answer here.
