Rotating Mass, Available Horsepower, and Acceleration
Posted: Fri Sep 25, 2020 12:44 pm
This thread is to be about "How engine and drive train modifications effect vehicle, acceleration, top end speed and power(ability to climb steep grades". It was triggered by another discussion about water pumps.
As a base line lets assume a 1917 -1926 perfectly tuned engine that runs perfectly well on magneto or 6volt battery, perfectly adjusted coils and uses a timer; has standard running gear and ratios. Also when discussing things like the effect of removing magneto magnets and replacing with oil slingers please refrain from mentioning the effects on the electrical system. Added accessories like HP drain from adding a water pump should be mentioned as well. If possible the horsepower difference in using a generator vs alternator.
I found this on the INTERNET https://www.w8ji.com/rotating_mass_acceleration.htm that discussing the effects and could be a good start:
Several common questions about rotating mass are:
Use a lighter crankshaft, how much power is gained?
How does flywheel weight affect acceleration?
How much acceleration can be gained from using lighter wheels?
Does a lighter driveshaft speed up my car?
A rotating mass does not really consume or dissipate energy. A rotating mass stores energy. The rotating mass eventually either returns energy to the system in a useful way, or something converts the stored energy to some other form of unwanted energy. The conversion might be with a friction, converting to heat. The energy stored also might not do anything at all, or the stored energy can even be harmful, reducing acceleration or braking.
Accelerating an unnecessary rotating mass requires energy, and the acceleration process saps some of the horsepower we have available to accelerate our vehicles. Reducing available horsepower affects acceleration in a very predictable manner, and the horsepower amount needed to spin something up gives us some feel for how important a part change might be (Think water pump).
