13T - Fuel Issues
Posted: Sat Sep 26, 2020 2:09 pm
				I’ve had some issue with a lack of power and the T running rough when the throttle is open more than halfway or so. Been going on since I got it back on the road about a month ago. I have a solution I’m working on just don’t have it in place yet.
I drove the T to my barber shop about an hour ago. T seemed to be running a little rougher than normal and I was having to adjust the carb mixture knob more than normal. After only a few minutes, I decided to go out and check on the T when I had a disconcerting feeling from the drive over. I saw the T was pouring gas out of the carb, almost a steady stream. I guessed the float was stuck open/down so it wasn’t cutting off the gas and free flowing as it overflowed the bowl.
I cut off the gas at the tank and it’s stopped the flow. I left the barber shop after maybe 45 min, turned the gas back on, and started after only 1 or 2 pills. Drive home, still rough, but got there with no problem.
Does that sound like a float problem? Any other thoughts?
Darin
Darin
