Removing the Steering Wheel
Posted: Sun Sep 27, 2020 10:02 pm
by BLB27
Can the steering wheel be removed on a 1927 T with out a puller?
Re: Removing the Steering Wheel
Posted: Sun Sep 27, 2020 11:35 pm
by Mark Gregush
Yes, no, maybe all depends on how tight it is.
Posted: Mon Sep 28, 2020 7:36 am
by Allan
The wheel is keyed on a parallel shaft, so there is no taper to break. If you sit in the car and load the wheel with pressure from your legs while tapping on the shaft with a soft faced hammer, it should come off. Or, you can remove the wheel/shaft/steering box cover as a unit, the same hammer can be used to drive the shaft out of the wheel.
Hope this helps.
Posted: Wed Sep 30, 2020 1:41 pm
by BLB27
Allan, I did what you said and off it came! Thanks.
