***1910-1911 2 Piece Driveshaft Cross Section***
Topic author - Posts: 542
- First Name: Martynn
- Last Name: Vowell
- MTFCA Number: 9908
- Board Member Since: 2012
The Driveshaft has a hardened end step that the roller bearing 2890 ran on (not sure how, probably case, it would be easiest). I'm assuming that it was deemed much cheaper to make a separate sleeve, harden it and just press it onto the end of the shaft rather than this method, which I can see there being some problems with, especially fitting that rivet.
Fun never quits!
- Last Name: Vowell
Re: ***1910-1911 2 Piece Driveshaft Cross Section***
Slight change, had to change the lock screw 2586 (a bit too short).
Fun never quits!
- Last Name: Vowell
Slight change to spool and thrust bearing.
Fun never quits!
- Last Name: Vowell
I think this may be the what this looks.....
Fun never quits!
- First Name: Alan
- Last Name: Long
Doesn’t the Universal Joint run against the bronze thrust / bush in the earlier units?
Alan
Alan
- First Name: Alan
- Last Name: Long
Martyn.
Looks perfect to me! Thank you for the great work you do with your drawings
Alan in Western Australia
