Closed Cab TT Question
Posted: Tue Oct 13, 2020 1:19 am
by Jeepbone1
Can anyone confirm that the screws that hold on the door glass trim are #8 fine thread? I’m finally installing the glass channels and glass in my doors and the screws seem a little loose. I’m hoping they don’t need to be retapped larger.
Brad
Re: Closed Cab TT Question
Posted: Tue Oct 13, 2020 3:17 pm
by kelly mt
I'll check my '25 TT and get back to you this evening.
Posted: Wed Oct 14, 2020 10:18 pm
by kelly mt
My TT uses a fine 32TPI screw.
Posted: Thu Oct 15, 2020 1:28 pm
by haptruck
My TT also has Oval Head Slotted 10-32 3/4 inch machine screws.
Posted: Thu Oct 15, 2020 4:47 pm
by DSWKPT
I got 10 32 oval head slotted screws from Fastenere. $11.30 for 25 screws. They’re 1 1/4 inches long. Don’t stock 3/4, but they’re easy to cut off. Went through the same question about 8 32 screws. Too loose.
Posted: Thu Oct 15, 2020 9:59 pm
by Jeepbone1
10-32 is the trick. Picked up some Phillips heads from the Big box store so I can button up the door until I can get to the local hardware to get the oval flat heads. Thanks guys!
Brad
