Need Rocky Mountain Brakes!
Posted: Thu Nov 05, 2020 7:14 pm
by Jonah D'Avella
Re: Please look at this link!
Posted: Thu Nov 05, 2020 8:54 pm
by John E. Guitar
Jonah,
You might get a better response if you edit the title to state that you are looking for Rocky Mountain Brakes. Most people don't bother looking at posts with non-descriptive or cryptic titles.
I'm in Australia so can't help with your actual request.
J.E.G.
Posted: Thu Nov 05, 2020 9:32 pm
by John iaccino
Jonah, I hope someone will correct me if I am wrong, but I believe the only difference between the large and small set-up is the addition of the extra brake drum. I think you can use your set-up and just omit the extra large drum that comes with the early brakes. John
Posted: Thu Nov 05, 2020 9:44 pm
The 26/27 RM's use brake bands that are a different size then the ones used with the small drum setup. The 26/27 used the existing drums, the small drum an additional drum that was installed between the wheel and original small drum. You can't install the small drum type bands on the 1926/27's.
Posted: Thu Nov 05, 2020 9:46 pm
by John iaccino
Thanks, Mark for the info.
Posted: Fri Nov 06, 2020 1:32 am
Pictures always help. So you have an early kit and want to swap for a '26-'27 kit?
Also here is a link on instructions '26 - '27 Rocky Mountain Brake Kit
https://www.fordmodelt.net/rocky-mountain-brakes.htm
Re: Need Rocky Mountain Brakes!
Posted: Fri Nov 06, 2020 10:52 am
https://www.modeltford.com/item/RMB2.aspx
https://www.modeltford.com/item/RMB.aspx
The photo of the 26/27 shown above is not correct. The kit does not include the brake drum.
