will pancake hasslers bolt to the rear of a big drum ruxtel
Posted: Mon Feb 25, 2019 5:21 am
by warwick_preval
Hi all will Hassler shocks bolt to a 26/7 big drum Ruxtel with( Rocky mountain brakes) so i can match the front hasslers on my 22 coupe cheers Warwick.
Re: will pancake hasslers bolt to the rear of a big drum ruxtel
Posted: Mon Feb 25, 2019 10:50 am
The older beehive style will not - shock mount to brake band conflict unless the mount base is "shimmed" out - can't comment on pancake style as I've not mounted any BUT the rear mount is quite different.
Posted: Mon Feb 25, 2019 11:11 am
by TonyB
I remember reading that cannot use Hasslers with the RM brakes because of interference.
If the original Hasslers would not fit the large drum rear end, it seems very likely that they would be redesigned for the 26/7 brake drum. Someone must know......
Posted: Wed Feb 27, 2019 12:35 am
by Kohnke Rebabbitting
The Pancake style were made especially for the 26-27's.
The fronts will fit all, but the rears only the large drum.
Herm.
Posted: Wed Feb 27, 2019 6:38 pm
by Wilbur
i have pancake Hasslers both front and rear on my 1924 Tudor with a Ruckstell rear axel. Just installed the new AC brakes. All fits and works well.
