Magneto post oiler caution.
Posted: Sun Nov 08, 2020 3:15 pm
While I no longer use a magneto post oiler, but, instead use the transmission mounted flywheel pressure feed oiler, caution should be observed when installing a mag post oiler. I once shorted out my magneto when, in screwing the fitting into the side of the mag post housing, it made contact with the pointed steel contact rod in the center of the unit. While some have addressed the problem by adding a spacer, I addressed it by removing the fitting and grind off some of the threaded portion of the fitting so it could be completely tightened without going in far enough to make contact with the steel contact post. It is a common occurrence and may be a reason why some, otherwise good, magnetos do not work. Jim Patrick
