3-Piece Bendix cover.
Posted: Sun Nov 22, 2020 5:16 pm
I just wanted to share my “new” 3-piece Bendix cover that I just got. It only has a small dent in it that needs to be straightened out. After I get around to doing that I will have to send it out to get zinc plated.
You can see how it compares to the later style Bendix covers.
This one is 3-piece construction with the top and bottom welded in place and the body piece being seamed together.
I have the early F.A. starter and generator with the early/different style cover for the brush end of the starters and generator, shown on page 277 of Model T Ford by Bruce McCalley (changed to the more common T-5101 cover band later). I also have the square cutout but I still need to find an early ignition switch with the cast handle and then I should have everything correct for the early lighting/electrical system.
