throttle linkage mod on 27 engine block
Topic author - Posts: 14
- First Name: Dex
- Last Name: Doucet
- * REQUIRED* Type and Year of Model Ts owned: Runabout
I need to run my throttle rod through the cylinders but the casting webbing is solid there. However there is a recessed portion about 1" squared that seems like it was made to be easily knocked out.. can I drill through it or drill and chisel that area to pass my throttle rod? Is this something yall are familiar with?? Thanks.
- MTFCA Number: 1219
Re: throttle linkage mod on 27 engine block
They talked about it here.
http://www.mtfca.com/discus/messages/29 ... 1188341007
Maybe there is better info.
- First Name: Dex
- Last Name: Doucet
Thanks Rich.
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
If I were doing it, I would definitely drill as opposed to using a hammer and chisel. I would cry for days if I send a crack in a direction that wasn't intended.
- Last Name: House
- MTFCA Number: 115
Do you still have the correct solid valve cover panel ? If so you’ll want to deface a hole in the middle of it too. ... #vaporizers
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
I did my ‘27 Tudor years back. The block had the hole and so did the valve cover but the cover gasket didn’t.
- Last Name: Zibell
- MTFCA Number: 30265
- MTFCI Number: 24046
Lang's sells a kit so you don't need the hole in the block. https://www.modeltford.com/item/6299CL.aspx
1926 Tudor
- Last Name: Warren
I would not open the block and valve cover! You have a sealed engine with a proper breather. The most of us have an open engine with the valve cover and block open to the elements. That is one of the reasons that I like the 2 valve cover engines. I did a mod on a couple of engines sealing them with a piece of tubing connecting the block hole with the valve cover hole. It works to seal the engine back up. I would, definitely, in your case consider the linkage option.
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
The throttle bracket makes the most sense to me, no molesting of the original block or "valve door" & not having to relocate the small lever on the throttle rod. George
- Last Name: House
- MTFCA Number: 115
Amen... other George
