What have you done with your T in December
Topic author - Posts: 209
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
Well ladies and gentlemen the last month of a year I'm sure we won't ever forget.
Got the new front spring and shackles together, waiting for the paint to dry on various parts and the spring clip bar. Will get in a few more miles on before setting up for winter and digging into band replacement.
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 LHD USA Touring 1916 RHD Canadian Touring 1916 Pickup
Re: What have you done with your T in December
Went to the Christmas tree farm in the T pickup to pick up this years tree. Merry Christmas to everyone here at the forum.
- First Name: Rolf
- Last Name: Oehman
Beautiful car and photo Warwick.
- MTFCA Number: 16175
- MTFCI Number: 14758
After several weeks of doing other things (cutting & splitting firewood, cleaning up storm damage, planting trees, etc.) today I got back to work on my mag ring.
Applying Kaptan insulating tape to copper ribbons. I put it on both sides. It's 1 mil, so the winding has 2 mils of insulation between layers.
Winding a coil. It took awhile to figure out how to tie a finished coil with wire so it won't unwind.
Four down, 28 to go.
- Last Name: Rogers
So when can we start sending you our mag ring cores for rebuilding?
- First Name: Andre
- Last Name: Valkenaers
- MTFCA Number: 23792
- MTFCI Number: 19330
Waiting for some parts this week so I rebuided a few coils.
Andre
Belgium
Andre
Belgium
- First Name: Andre
Steve, fine to see you back on the coilring.
You can use a 3/8 wide tape to block the end of each coil.
Don't forget to insulate the side of the coils at the place you plie over the strip to make the connection part of each coil.
Good luck
Andre
Belgium
Good luck
Andre
Belgium
I'll leave that to Andre and RV and others. I hardly ever finish anything as it is. I don't need to take on anything new.
- MTFCA Number: 30701
- MTFCI Number: 24033
Stored them!
- First Name: Ken
- Last Name: Lefeber
- MTFCA Number: 31968
Celebrated Wilma's 94th birthday with a short ride to the recently opened Johnsonville Marketplace.
- First Name: Anthonie
- Last Name: Boer
- MTFCA Number: 19790
This morning I put new pistons in a friends engine , and mount the coilring and flywheel.
Toon
Toon
- Last Name: Boer
And the Magneto is working OK
Toon
Toon
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
I did the last bit of disassembly on my rear axle. I was putting it off because I didn’t have a sleeve puller but I made one.
- First Name: Ryan
- Last Name: Fenrich
- * REQUIRED* Type and Year of Model Ts owned: Speedster Project
I finally began cleaning up my field coil rings. The apparatus is a little crude, but it works just fine.
15 more to go.-
- Last Name: Jorgensen
- MTFCA Number: 31697
- MTFCI Number: 23399
It was 50 degrees and sunny yesterday in Batavia, IL, so ....
I was able to give the T a little exercise. Started on the 2nd pull.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Started freehand lettering (with patina) the truck. Enjoy
- Last Name: Codman
Started on the job of adjusting the clutch screws. The floormat is out, as are the front floorboards. The transmission top cover is off and the left rear wheel is jacked up. I'm hoping that in the next couple of days I will pull the spark plugs, then I'll have a go at actually doing he adjustment. Tomorrow is a birthday party for an old friend who is moving a couple of hundred miles away, so probably no progress until Saturday.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Got to get the boat done! Oh.., it will be towed behind a 1927 RPU on a period correct trailer and 1926 Johnson outboard. It only weighs about 90 lbs, White Cypress.
Priorities Man!
Hank
Priorities Man!
Hank
- First Name: Danny
- Last Name: Deaton
Got my small tanks filled so I can rivet Saturday
- Last Name: Wendt
That is cool Hank, post some pictures of that Johnson. I acquired a 25 last year, these are pretty rare indeed.Henry K. Lee wrote: ↑Thu Dec 10, 2020 5:22 pmGot to get the boat done! Oh.., it will be towed behind a 1927 RPU on a period correct trailer and 1926 Johnson outboard. It only weighs about 90 lbs, White Cypress.
Priorities Man!
Hank
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Here you go Scott!
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
Absolutely nothing
I’ve been working on my new (to me) house. Sanded the floors, some new drywall and refurbished the kitchen cabinets. I hope to move all the stuff in the workshop after the house move and resume T work in February.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Michael
- Last Name: Peternell
And a picture of the elves you have working in the shop. You are a busy sum bitch!Henry K. Lee wrote: ↑Sat Dec 12, 2020 7:51 pmHere you go Scott!
- Last Name: Wendt
Hank that is outboard eye candy, I will stop procrastinating on mine and give it some shine. I also have the brass lower prop and tank needs the fresh paint and decals.
Thanks for posting the pictures and love those old adds.
- Last Name: Codman
Henry, I love those old wooden boats! Also modern replicas of them.
I haven't worked on any of mine, however, am installing a new top on a 1920 owned by a member of our club. The hardest part is done. The bows have been wooded and pads installed with alignment of the bows. The windbreaker and rear panel are installed. Next, when we have another warm day, will be the top itself. Here at this time of year, we can go from rain, fog, hail, wind or warm sunshine. Some days get into the 70's and 80's. In 46 years we have lived here we have only had about an inch of snow a few times, usually if it is cold, there might be a few snowflakes mixed with light rain. We got some autumn leaves, but the next day the wind came up and blew them all away. About 2 weeks ago the wind got so strong it split a large Oak so I also have a lot of wood to cut up and maybe enough firewood for several years! So I work on the T when my knees and back are not bothering me. I try to do a few hours work each day but vary it from day to day. Sometimes raking leaves. After it rains there will also be weeds to cut and in winter some trees to prune. Anyway, when the top is on, the T will be almost ready to go home.
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
- MTFCA Number: 50718
I am making the best of a fourteen day Covid quarantine and installed the fenders and hood. I still have to paint the correct fender bolts and screw the hood former to the firewall. I have thirteen days left so I am stretching it out. Art
- First Name: Reuben
- Last Name: Kugel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
- MTFCA Number: 49871
- MTFCI Number: 24323
Got new E-brake linings on the speedster. Pulled the carb of the 15 Touring to discover that the float was set about an 1/8" to high. reset to 1/4". Also discovered there was no gasket between float bowl and carb body. Glad I had one. Carb reinstalled back on car. Now in the middle of rewiring the entire 15 Touring. Long winters hear in Wisconsin are a great time for some tinkering.
1915 Touring
1926 RAJO Speedster
1926 RAJO Speedster
- Last Name: Aldrich
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
In the "parts gathering" mode so a buddy of mine and I can build a Depot Hack.
John Aldrich
Typical Model T Addict
- Last Name: Warren
Nice Boat and motor, Hank. You are a man of many talents. SUPER JOB. thanks for sharing jw
- First Name: Mike
- Last Name: Kossor
- MTFCI Number: 22706
Busy working in Santa's Model T work shop; he knows who's been naughty (?) and Nice. Better be good for goodness sake!
Happy Holidays!
Happy Holidays!
I had two days of city driving on promotion work for Haigh's chocolates. Yum. Second day out, the Holley H1 resumed it's leaking when I stopped the van outside a couple of the stores. Then it decided to behave itself for the rest of the day.
I might finally have to fit one of Stan's H1 rebuilt carbs that looks too good to get dirty. At the same time, I can fit another alloy manifold which has no welding repairs and fix an exhaust manifold leak.
- Last Name: Bailey
- MTFCA Number: 50335
Attended a Christmas "Covid" parade for the town. People could watch safely as the cars drove past their homes. Lots of fun but dang cold.
Still crankin old iron
- First Name: Neal
- Last Name: Willford
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
- MTFCA Number: 50256
When you have temperatures in the mid 50's in December, you take advantage of it! Our 15 runabout sits low enough with the top up that I can get it out of the garage with the top up with 2" to spare. Our 21 touring is a few inches taller and requires the top down before backing out, or it will be a bad day. When it is time for a quick spin, it's never much of a choice which one I take!
- Last Name: Bailey
Fantastic car Neil and what a clean garage....
- MTFCA Number: 52564
Redid 5 coils, 4 with new points 5th is waiting. When I sold the 1921 huckster all my working coils went with it. Just finished up regapping the vibrators on the 4, need to check now on the HCCT. Can't drive the 25 without them! Got a Craftsman tilting head band saw yesterday. Need to get carbon paper to start make patterns so I can rewood it. Don't want to cut the plans up.
1920 Dodge touring
1920 Dodge touring
- Last Name: Nunn
- MTFCA Number: 50321
I removed and disassembled my front axle and spindles. I boxed them up to send out for repair and bushings. I'm waiting until after the shipping companies get caught up before send them out. I have one inner bearing race that can spin in the hub. I'll need to address that when parts arrive.
- First Name: Danny
- Last Name: Deaton
I spent all day yesterday trying to find these two items
I found them after giving up twice
- First Name: Vernon
- Last Name: Worley
- MTFCA Number: 49462
2020 has been interesting, haven't had much time for the Model T. On the pickup had an engine wear out at 250k miles so rebuilt an engine and its transmission had a failed torque converter. So, got one from the junkyard, rebuilt it and installed at the same time as the engine. Wife's car had a flat tire and was returning from the tire store when the transmission on it gave out completely, coasting home. Back to the junkyard for a transmission. Lost two relatives this year, one to COVID. But we still have each other and our jobs. Overall, I enjoyed this challenging year and we finally got the floor welded to the body.
Vern (Vieux Carre)
- Last Name: Codman
I always enjoy reading this monthly post. I am constantly amazed at the talent that I see here. This is an amazing group. Merry Christmas to all!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Finished up the 27 for a friend.
Moved the RPU into the new shop and started the RM brake install.
Discovered I dont need to fight wire or zip ties to change the brake peddle. The visegrips worked great.
