Is there a way to keep the u-joint grease in?
Topic author - Posts: 279
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
When I pulled my engine, I found that the u-joint was pretty well emptied out of grease. That was after maybe 200 miles of driving. It had escaped from the ball shaped driveline connection and made a real mess. Has anyone found a way to better contain this stuff in operation? I am using the pastey, fibrous type grease here.
Cheers, Bill
Cheers, Bill
- MTFCA Number: 52564
Re: Is there a way to keep the u-joint grease in?
You can get a shim for loose fitting balls. Did you by any chance have a gasket between the ball cap and 4th main? There should not be one there if you did. The only gasket in that area is the one between the 4th and back of hogs head. Also, how well does the output/tail shaft fit in the 4th and is the plug in the the output/tail shaft? Looseness or lack of plug can lead to excess oil washing out the grease.
1920 Dodge touring
1920 Dodge touring
- First Name: Bill
- Last Name: Hoffer
Mark, I think you hit it! There was a gasket between the ball cap and the rear ball connecting gizmo. Stands to reason it would create a super loose fit at that point. The ball appears to fit up well. Thanks a million! Bill
- MTFCA Number: 30701
- MTFCI Number: 24033
Make sure you pack that ball FULL of grease when you put it all back together!
Then, every 500 miles it'll be a lot easier to keep it full of grease. I prefer to use the zerk-fitted grease cup
that you can get from Langs. Not expensive, sure makes keeping the U-joint ball filled. Got 'em on both
my cars. This is where I say "to heck with purism"!! Gotta be pragmatic sometimes.
Thank you! If I have it on hand, I would use the red grease. I think the type of grease you are using is ok for wheels that have more open bearings, the grease needs to get inside the joints in the u-joint. Yes I too have used that type, the stringy, but on reflection, don't think it is a good idea in this location. More often then not, the grease I use is what is at hand. I am not really worried mixing or that it might have something in it that might short out the mag. More then likely it is going to flow down the tube or out the ball joint as it is diluted with engine oil, not into the engine.
1920 Dodge touring
1920 Dodge touring
- First Name: Bill
- Last Name: Hoffer
Thanks again guys. The engine is freshy rebuilt, so it is likely any oil flow will go towards the tube. All of that stuff is freshly rebuilt, too, so I should be good to go for quite a while! Cheers, Bill
I was wondering if 5th wheel grease would be a better solution for the ball end. I would prefer a grease for the ball end to be "water proof" not just "water resistant"
Frank, I've been using the "Red 'n Tacky" ever since starting with Ts in 2012. I think it works super good. Just my opinion.
Thanks lots of brand's to choose from. Question : does it leak out much? Some owners have complained about the grease that they use (brand?) leaking and making a mess.
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Like I've posted before, Get a Huggies super absorbant diaper and wrap it around and you won't drip grease out all over the driveway. Change it every oil change.
1912 Torpedo Roadster
- Last Name: Thompson
I use John Deere corn head grease.
- First Name: Jim
- Last Name: Boyer
- * REQUIRED* Type and Year of Model Ts owned: 1927 T truck. 1927 T roadster
I have noticed several posts using corn header grease for several different things, is there something special about corn header grease?
Thanks for your input. Jim
Did some Internet searching...
"corn head grease is a poly urea based NLGI 0EP grease. commonly used in corn headers and similar boxes. It is a semi-pourable grease suitable for some gear boxes as it will slump to prevent cavitation voids like a #2 grease might cause. I would not recommend it as gun grease for grease fittings."
From https://www.cenex.com/~/media/cenex/fil ... h9-02.ashx
Multi-purpose Semi-Fluid Grease
General Description Corn Head Grease is a high quality multi-purpose, semi-fluid type grease available in an NLGI #0 grade. Although primarily applied in corn head lubrication, this product can be recommended for many applications in agriculture, automotive, construction and industrial environments.Corn Head Grease is a carefully formulated lithium 12-hydroxystearate grease with oxidation, rust and corrosion inhibitors, extreme pressure (EP) additives for anti-wear and heavy shock loading, and a special polymer to control oil separation during storage. The base oil used is a high viscosity index lubricant which provides excellent stability under various temperature conditions.Corn Head Grease has superior water tolerance and resists water washout, exhibits good high temperature capabilities and has outstanding mechanical stability by retaining its consistency in hard use.
