What is this for?
Posted: Tue Jan 19, 2021 7:50 pm
Spacing of the corner holes is the same is early front spring clip
Re: What is this for?
Posted: Tue Jan 19, 2021 8:17 pm
by John Warren
I would say it is a front spring clamp plate that can be used for early and late cars
Posted: Tue Jan 19, 2021 9:02 pm
It could well be from a horse drawn light jinker.
Posted: Tue Jan 19, 2021 10:37 pm
It was an accessory front spring clamp bar - apparently, the earlier double u-bolt bracket was a "better idea" !
Posted: Tue Jan 19, 2021 11:03 pm
Spring Plate, added strength to front crossmember to help prevent front spring breakage.
Posted: Tue Jan 19, 2021 11:54 pm
by jiminbartow
Dan, you are a virtual cornucopia of knowledge.
I thought it might be used to lower the front end by flattening out the arc of the front spring. Maybe a lower front end was thought to be more trendy and sporty. Jim Patrick
Posted: Wed Jan 20, 2021 1:31 am
DanTreace wrote: ↑Tue Jan 19, 2021 11:03 pm
Thank you for the ad - explains the purpose
Posted: Wed Jan 20, 2021 1:35 am
by kmatt2
I have one on a TT chassis that saw hard use. Original pictures of TT's at work will sometimes show these.
by Scott C.
My 26 Coupe has one on it.
