Rear Hub Reamer
Posted: Wed Jan 27, 2021 6:30 am
by dang.1922
I am working on a Farm Tractor Co. of Fond Du Lac Wi. conversion and I am building the rear roller sprockets ( I have one 4 roller original for a pattern). I have the rough taper machined in and would like to know if anyone makes a finish taper reamer for the bore? Thank You for any help. Dan Greger
Re: Rear Hub Reamer
Posted: Wed Jan 27, 2021 3:39 pm
by Billy Vrana
Can't help you with a ream, would it be possible to turn down a hub and build from that? Or maybe call the company,
Re: Rear Hub Reamer
Posted: Wed Jan 27, 2021 3:47 pm
by Kevin Pharis
The tapers are a standard 3/4ā per foot taper... Iām pretty sure that is measured per side, not included. The tricky part is getting the gauge point at the right dimension from the inner face. The drive key can be a challenge too. Good luck
Re: Rear Hub Reamer
Posted: Wed Jan 27, 2021 3:52 pm
by Jerry VanOoteghem
Kevin Pharis wrote: āWed Jan 27, 2021 3:47 pm
Drop an appropriately sized ball bearing into the taper that you're cutting. Measure how far it goes in and compare that to the same measurement in a GOOD, stock, Model T rear hub.
It's possible to make the taper on a lathe, even one that doesn't have a taper attachment. It does however take a bit of tinkering to get it "dialed in ".
Re: Rear Hub Reamer
Posted: Wed Jan 27, 2021 4:13 pm
by Kevin Pharis
Jerry VanOoteghem wrote: āWed Jan 27, 2021 3:52 pm
Absolutely right...! Best to use 2 balls of different sizes to ensure the taper is correctly sized at both ends. And this introduces yet another tricky aspect... remembering to remove the ball bearings after each measurement
Re: Rear Hub Reamer
Posted: Thu Jan 28, 2021 7:36 am
by dang.1922
Thank You All for your information, I never thought of using a ball in the tapered bore for getting the correct size, I will do just that. I turned a taper on a piece of round stock up and machined a 1/4 in. keyway in it to use as a mandrel to broach the key slot in the new sprockets. ----Dan Greger
Re: Rear Hub Reamer
Posted: Thu Jan 28, 2021 12:02 pm
by John Warren
Re: Rear Hub Reamer
Posted: Thu Jan 28, 2021 12:23 pm
by Kevin Pharis
dang.1922 wrote: āThu Jan 28, 2021 7:36 am
Good luck with the keyway... I started with a broach key and tapered mandrel, but found that I could not keep the assembly together while pushing the key from the small end, and the mandrel would pinch the broach key when pushing from the big end. I ended up building a fixture in my shaper to get the job done
Re: Rear Hub Reamer
Posted: Thu Jan 28, 2021 12:57 pm
by Farmer J
Dan. Sounds like a job for the boys at Kramer Power Equipment Jerry K
