Correct 1924 Cowl Fasteners
Topic author - Posts: 451
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Would someone post the correct size and type of bolts and nuts needed to fasten the cowl to the body and to the firewall please. My car had a mismatched variety when disassembled. There are four places to fasten to the firewall and two or more to the body I think, please correct me if I am wrong, Thank You [/size][/b]
- Last Name: Snell
Re: Correct 1924 Cowl Fasteners
If anyone has original photos that shows the bolts fastening the cowl to the firewall, please post. Thanks
- MTFCA Number: 1219
I believe these are untouched since the factory.
RichWhen did I do that?
- Last Name: Snell
Thanks for posting Rich. Are the two upper fasteners Carriage bolts? What is the wrench size for the two upper hex nuts?
Yes, the upper are carriage bolts too. I couldn't measure the heads but they are not the extra small ones like on fenders or coil boxes. The nuts are slightly bigger than 1/2 with the rust on them. Getting a standard 1/2 open end wrench would be tight. The bolts are 5/16". This is a '24 Tudor but the bolts would be the same.
- MTFCA Number: 121
- MTFCI Number: 16310
Don't forget the piece of felt that goes between the firewall and cowl. Yours takes five split rivets, which are the same ones used for the cowl lacing.
- Last Name: Snell
Thanks Original, I will use your design rivets for that as well!
- Last Name: Snell
I would guess the two outer carriage bolts would be 1 1/2 or 2 inches long to get through the pillar where the center two are maybe 3/4 inch long or so.
