Screw size for dash shield
Posted: Sun Feb 07, 2021 4:17 pm
by Tbird
I just got a dash shield and guide for a two piece dash 11-12. Unfortunately the dash shield did not come with the mounting hardware (screws).
I do know that the screws are to be #6 Slotted Round head but what is the length? Thanks
Mike
Re: Screw size for dash shield
Posted: Sun Feb 07, 2021 4:33 pm
by Allan
Not so long that they go right through the firewall. No-one will know if you use some thatare a bit shorter than Henry used.
Posted: Mon Feb 08, 2021 12:40 am
by KWTownsend
Mike-
I'm sure someone who has those specifications will post it. Regardless of the length, I would suggest you drill the holes and "thread" the wood using a matching thread steel Phillips head screw before you put in the slotted French head brass screw.
Those fancy brass screws have a tendency to twist in two. Don't ask me how I know.
Keith
Posted: Mon Feb 08, 2021 10:13 am
by Original Smith
Keith, I hear you on that one. I had it happen to a #8 oval hood former screw. It was a chore to remove it.
Posted: Mon Feb 08, 2021 4:51 pm
by Hudson29
Years ago an old timer told me to soap wood screws to ease their passage into the wood. Is anyone doing this now? Do they come loose more easily?
Posted: Mon Feb 08, 2021 5:20 pm
by Tbird
Great ideas guys!
Mike
Posted: Mon Feb 08, 2021 9:42 pm
by It's Bill
Soap definitely works! Dad's favorite trick. Great idea on prethreading the hole! Cheers, Bill.
Posted: Mon Feb 08, 2021 11:12 pm
by MikeinTexas
Dad's trick was to scrape the woodscrew threads across a piece of Bee's Wax!
Something I still do!
Posted: Mon Feb 08, 2021 11:30 pm
by dr1960
I have used the soap and bee's wax trick for years! My grandfather always had a small bar of soap in his toolbox and he would drill a hole in the wooden handle of his hammer and put bee's wax in it so as to always have it on hand!
Posted: Tue Feb 09, 2021 2:18 pm
by Hudson29
I just ran the No. 9 brass wood screws into the dash to hold the horn. It was hard going in dry, I had forgotten the old wisdom. Oh well, next time!
