Preserving engine numbers.
Posted: Mon Feb 08, 2021 2:36 am
In a recent post on engine numbers, various suggestions about stamping numbers and retaining the original number were canvassed.
I had a legitimate reason to adopt the following preservation method.
I removed the side water outlet from the engine and made an accurate tracing of the outlet hole and the engine number boss.This was transferred to a brass sheet and the sheet was cut to the pattern. I stamped the required number onto the brass sheet and then dressed the sheet back to a nice flat finish, the stamping having dished it somewhat. Then a heavy coat of RTV was applied to the engine side of the sheet, and the plate was fitted next to the block and held in place by he usual gasket/sealant/outlet and bolts. A quick wipe off of the excess sealant squeezed out around the plate disguised the fact that it was even there. A handful of red rust coloured dirt in the uncured RTV made mine look quite at home. A coat of paint on a restored car would do the same.
This technique would allow you to use a donor engine while rebuilding/preserving your original. It might also allow you to match an existing replacement engine to the number shown on a title. The beauty of it is it is completely reversible if and when circumstances demand.
Sorry about you unfortunates with early cars with engine numbers elsewhere on the block.
