Making a Ruckstell spider
Tlitwin
Last Name: Litwin
* REQUIRED* Type and Year of Model Ts owned: 1926 touring
Post by Tlitwin » Mon Feb 08, 2021 4:00 pm
What’s the best way to cut down a read end spider to fit a Ruckstell rearend? Grind it down or hack saw. Or?
Tom
RGould1910
Last Name: Gould
Re: Making a Ruckstell spider
Post by RGould1910 » Mon Feb 08, 2021 4:58 pm
I've always ground them. They are hard. Don't know if a hack saw would work
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Feb 08, 2021 5:29 pm
Cutoff wheel or grind, but keep it cool so you don't draw the hardness out of it. If it gets blue, its too hot.
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Tue Feb 09, 2021 11:12 am
Put it in the carrier and use a flap disk on an angle grinder 15 minute job tops.
Having it in the carrier keeps it from overheating and gives the arms the correct length.
Tlitwin
Last Name: Litwin
Post by Tlitwin » Tue Feb 09, 2021 1:35 pm
Thanks all for the tips. Like Stan’s tip on keeping it the carrier so it stays cool.
Tom
