What’s the best way to cut down a read end spider to fit a Ruckstell rearend? Grind it down or hack saw. Or?
Tom
Making a Ruckstell spider
- Last Name: Gould
Re: Making a Ruckstell spider
I've always ground them. They are hard. Don't know if a hack saw would work
- First Name: DAN
- Last Name: MCEACHERN
Cutoff wheel or grind, but keep it cool so you don't draw the hardness out of it. If it gets blue, its too hot.
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Put it in the carrier and use a flap disk on an angle grinder 15 minute job tops.
Having it in the carrier keeps it from overheating and gives the arms the correct length.
Topic author - Posts: 84
- First Name: Tom
- Last Name: Litwin
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
Thanks all for the tips. Like Stan’s tip on keeping it the carrier so it stays cool.
Tom
Tom
