Unknown Part - 1924
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
MTFCA Number: 31662
MTFCI Number: 23677
Board Member Since: 2014
Unknown Part - 1924
Post by SurveyKing » Wed Feb 10, 2021 4:35 pm
In going through labeled bolts/nuts from the disassembly of my 1924 Touring, I cannot seem to recall where this part came from. It was in a bag of bolts marked Cowl/Dash. The piece is steel and measures 1 1/2" by 1/2" by 1/4" thick and is threaded to accept the threads on the screw shown. Can someone identify this for me? Thanks
MTFCA Number: 1219
Re: Unknown Part - 1924
Post by Rich Eagle » Wed Feb 10, 2021 5:31 pm
How about a windshield stanchion screw (to dash) and a bar to hold it? The lower screw would use a nut but the upper is difficult to put a nut on.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Wed Feb 10, 2021 5:37 pm
Richard is correct. On my '24, both screws had a nut plate like that and the plates were a different length (I put the long one on top). :)
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Wed Feb 10, 2021 8:57 pm
So are there supposed to be two, one for each stanchion?
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Wed Feb 10, 2021 9:54 pm
Yes, one for each side of the stanchion to dash panel, on the lower machine screw. The gap at the dash is very tight and a wrench cannot be used, so that long length nut is a 'jam' and 'spacer' nut, (Part # 1307RX. {23-25}), fits into the gap and resists moving as you tighten the oval head screw.
The upper screw can use a normal nut as a wrench can fit there with ease.
long bar nut.jpg (84.36 KiB) Viewed 2405 times
special lower nut in place.jpg (62.5 KiB) Viewed 2405 times
upper nut on stanchion.jpg (94.76 KiB) Viewed 2405 times
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Feb 11, 2021 3:18 pm
As I recall, those are for the dash. The short one on the bottom, and the long one on top. They are not for the windshield posts.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Feb 11, 2021 3:31 pm
I'll eat my words. They are more the the dash, however they do attach to to the windshield posts. I should have thought about this more before I posted. The short one on the bottom, the long one on top.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Thu Feb 11, 2021 5:41 pm
Original, are there two for each windshield stanchion? One short and one long?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Feb 12, 2021 10:30 am
yup. Here is a pair of NOS nuts that I have.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Fri Feb 12, 2021 4:49 pm
Would you care to sell them to me Original Smith?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Feb 13, 2021 10:10 am
I don't have time to go through all the boxes of NOS parts I have! All you need is a sample of each. They would be quite easy to make.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Sat Feb 13, 2021 10:30 am
Ten Four, thanks
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon Feb 15, 2021 3:57 pm
Here are the dimensions of the last two NOS nuts I have. They can be easily made.
Long: 1 1/2" X 7/16" X 1/4". Short 1" X 7/16" X 1/4". Both are threaded 1/4-20. Oval head slotted screws are used.
