1909-10 Brass Timer contact ring
Posted: Sat Feb 20, 2021 1:11 pm
by Tourabout
Does anybody make new contact rings for the brass timers? This is the contacts inside the timer that the roller makes contact with. Also, does anyone make rollers for them?
Robbie
Re: 1909-10 Brass Timer contact ring
Posted: Fri Feb 26, 2021 8:20 am
by Scott Rosenthal
Hi Robbie:
The early contact ring is similar but not identical to multiple later styles. I was able to retrofit a contact ring that I liberated from a T-3165 repro timer that I got from Snyders, by installing a shim between this ring and the original bronze housing diameters. The shim needs to be a non-conductive material, such as fiber board or plastic....very simple.
I have a cast repro rotor that I've had to do some surgery on when the steel pin that the contact roller carrier pivots on, worked its way loose... fortunately that this didn't turn the timer into a grenade.
Not sure whether anyone currently makes an early style rotor, as the repro I have was among a collection of parts that a friend acquired, and then sold to me....could be a 49 year old repro for all I know. In addition to it's cast construction, it's roller and axle is a basic arrangement where the roller wobbles a bit on the axle (could be this is by design?). I've thought about reproducing a higher quality version of these, but as has consistently been the case with this real early stuff, there simply aren't enough customers out there, to make the tooling and manufacturing effort worth the while. Hope this helps.
Regards,
Scott
Posted: Fri Feb 26, 2021 9:14 am
by RGould1910
Don Tyler of Rising Sun Ohio has made timers for two cylinder Fords. Try contacting him via the Early Ford Registry. If you come up dry, I may have his info somewhere.
Posted: Fri Feb 26, 2021 9:27 am
by RGould1910
If you have access to a mill and lathe you can make a contact ring out of a large bar of delrin. The cut outs for the contacts can be made with a keyway cutter. The moon shaped contacts made from steel bar stock drilled and tapped for the posts. Delicate work but doable.
Posted: Fri Feb 26, 2021 11:40 am
by Joe Bell
I think there is one in a box of timers and a few of the brass rollers are there also, you are close enough to come see if it is what you want?
Posted: Fri Feb 26, 2021 1:59 pm
by Tourabout
Joe,
I will email you,
Thanks,
Robbie
Posted: Fri Feb 26, 2021 2:13 pm
by Joe Bell
I looked in the barn and found the new one.
Posted: Fri Feb 26, 2021 8:00 pm
by Joe Bell
Here's the pictures.
Posted: Fri Feb 26, 2021 8:03 pm
by FreighTer Jim
D@mn Joe
You got cleaner hands than I do
FJ
Posted: Fri Feb 26, 2021 9:17 pm
by Joe Bell
I have had only one Model T engine show up clean, the rest are oily cruddy messes, the only time my hands are clean is when the wife talks me into a weeks vacation down south!
Posted: Fri Feb 26, 2021 9:24 pm
by Tourabout
Joe,
That looks like it. Let me see if I can measure mine here in a few.
Robbie
Posted: Sat Feb 27, 2021 6:35 am
by Tourabout
Joe,
Mine measures 2 13/16 diameter and approx 5/8” deep.
You mentioned rollers.
I found a picture of some rollers from a sales site.
Posted: Sat Feb 27, 2021 6:54 am
by Joe Bell
I have half a dozen of the brass ones, some have a bigger backing plate.
Posted: Sat Feb 27, 2021 9:55 am
by Tourabout
I think the bigger backing plate is what I need
Posted: Sat Feb 27, 2021 10:10 am
by Tourabout
Here is a better picture of the rotor.
Posted: Sat Feb 27, 2021 12:09 pm
by Joe Bell
I am sure there is two of them. same area code as you 618-1025
