Field Coil Final Assembly Questions
Posted: Mon Mar 22, 2021 2:22 pm
I’m almost ready to finish my field coil. Just need to trim the ends, connect and solder, then seal with glyptal. I bought a fairly expensive two-part epoxy for use in electrical applications. I’m wondering if this is necessary to fasten the coils to the insulating paper to the ring. Some coils fit tighter on the poles than others, but after hammering them on with the block of wood, I just don’t see any way of them coming off. I haven’t even gone all the way down yet on them. I don’t really want to remove them just to apply epoxy for fear of damaging the insulating tape in the process, and in the event I have a ground or anything after soldering which would require I remove them, I wouldn’t hold my breath on the tape or insulation staying intact after the epoxy cures.
I’ve never seen any rebuild use adhesive. It looks like the tight fit of the coils on the poles and the glyptal to be enough. However, that assumes that there is sufficient tightness for all coils. I don’t know what “sufficient” would be defined as, but so long as they require a number of hammer ons to lower all the way, I’d think that’s enough.
I’m looking to proceed without epoxying for convenience, cost (if I take the epoxy back), and the ability to undo any mistake down the line before installation in the car. I’m hoping to hear some opinions before I proceed.
