Thrust washers
Posted: Tue Mar 30, 2021 10:09 am
by wrees
When replacing thrust washers, do thrust plates go on either side of thrust washers or both towards pumpkin?
Re: Thrust washers
Posted: Tue Mar 30, 2021 10:22 am
by Steve Jelf
Sandwich. Steel bread, bronze filling.:D
Re: Thrust washers
Posted: Tue Mar 30, 2021 10:37 am
by Mark Gregush
And steel thrust washers are kept from rotating by pins in the axle housings and on the differential cases.
Re: Thrust washers
Posted: Tue Mar 30, 2021 11:56 am
by jab35
Walter: If those pins are worn away or missing you need to install new ones before assembling the unit. The 'Axle Handbook" explains this. Without the pins holding the steel washers in place it's possible for the washers to ride on the axle shaft and wear a groove in the shaft. If this has already occured, I suggest replacing the axle out of safety concerns. Good luck.
