				What is this hole for?
				Posted: Thu Apr 01, 2021 10:14 pm
				by NY John T
				Hi All,
I just took off the heavily occupied (mouse nest) radiator of my 27 Tudor and noticed this hole in the front of the block (August 23).  Can someone tell me what it's for and do I need to replace what ever was there originally? Belt tensioner?? Thanks,
John
				Re: What is this hole for?
				Posted: Thu Apr 01, 2021 10:19 pm
				by Mark Gregush
				The fan and pulley.
				Posted: Thu Apr 01, 2021 11:35 pm
				by kmatt2
				That hole and the boss with the bolt next to the hole were used for the fan bracket and fan belt adjustment on a pre 1926 T.  Your 1927 car would have used a timing gear cover with out that hole or boss from the factory. I assume your 27 car is using a 27 fan, mounted on the head water outlet to raditor.
				Posted: Thu Apr 01, 2021 11:47 pm
				by Bill Coyle
				Adding to what Kevin and Mark said.  Your 27 T should  have the fan and pulley mounted to the water outlet that bolts to the cylinder head.  The belt adjustment is made by turning the eccentric which holds the pulley shaft.
Bill Coyle
				Posted: Fri Apr 02, 2021 9:36 am
				by NY John T
				Thanks so much for the comments.  The engine is a 23 in the 27 Tudor.  It has the fan attached to the water outlet pipe.  Now I know. Thanks.
John
				Posted: Fri Apr 02, 2021 10:07 am
				by TWrenn
				That is one interesting looking timer. Be sure to open it up and inspect and clean it and even make sure it'll work!!
				Posted: Fri Apr 02, 2021 11:17 am
				by speedytinc
				The late 26, 27 cam covers do not have the boss with bolt for fan bracket adjusting as mentioned. They still have the large hole take 1/2" fine bolt.
				Posted: Fri Apr 02, 2021 11:53 am
				by RajoRacer
				Recto Timer - I've seen an ad for that one somewhere.
				Posted: Fri Apr 02, 2021 12:38 pm
				by Steve Jelf
				One of the many aftermarket timers to go with the many, many, many aftermarket spark plugs.
