Carb adjusting rod
Posted: Thu Apr 01, 2021 10:37 pm
by tommyleea
23 T Roadster...Do any of you have problems with your carb adjusting rod, firewall to carb, turning on its own? When I get mine adjusted to where I want it, the vibration of the T seems to make the adjustment turn. I must be missing something that would put some friction on this rod..I don't have a grommet in the firewall. Maybe that is what's missing? Thanks...Tommy
Re: Carb adjusting rod
Posted: Thu Apr 01, 2021 10:56 pm
by Afrazer
Had the same problem on a Kingston L4 carb. I just replaced the carb adjustment needle clamp nut and snugged it down real good and that solved that problem the remaining time I had that carb on the car. The old clamp nut must have been wore down on the inner diameter and wasn’t holding the needle under driving vibration anymore.
Posted: Thu Apr 01, 2021 11:55 pm
David nailed it. Just tighten/replace the brass nut that clamps the mixture needle.
Posted: Fri Apr 02, 2021 9:00 am
by tommyleea
Thanks..Will do..Tommy
Posted: Fri Apr 02, 2021 10:28 am
Don't go hog wild getting it tight. Snug enough that the rod does not turn on it own, but loose enough that you can still turn it without forcing it.
Posted: Fri Apr 02, 2021 10:36 am
by tommyleea
Copy..Thanks
