How do I fix this ?
Topic author - Posts: 154
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
How do I fix this ?
So I put on a new flat tube radiator and can't adjust the spacing of the hood properly.. the problem is I only have a half inch between the fan and radiator.
- Last Name: Rutt
Re: How do I fix this ?
Sorry thing to post a picture
- First Name: Nikolaus
- Last Name: Martin
- MTFCA Number: 32342
- MTFCI Number: 23512
I see you have a ‘26. You might have a long fan hub for a thin core, and the new radiator is a full thickness core. You might need to just find the short version of the fan hub.
What era fan and/or bracket? 1909 to about 1919? About 1918 to 1925? 1925 to 1927? If 1925 to 1927, which of at least three variations?
The brass era brackets are almost fool-proof. The about 1918 to 1925 brackets can actually be put on backwards. I forget which way does what, but the forward to back placement does shift a bit. The late 1925 through 1927 variations get more complicated. Also, there was a longer fan hub used for awhile that moved the fan closer to the radiator, (the radiator being used for a short while was thinner and needed the fan moved forward).
Best suggestions will need more information.
- Last Name: Rutt
- Last Name: Martin
That is a long fan hub. It goes with a thinner core.
http://www.mtfca.com/discus/messages/50 ... 1448260540
- First Name: Joseph
- Last Name: M
- MTFCA Number: 0
- MTFCA Number: 28924
You need the shorter version fan hub. You can call Lang’s tomorrow and ask if they have a good used short version. They also sell the newer ball bearing hubs that might fit but they would cost a bit more than an original used on. They do have a supply of used parts.
- MTFCA Number: 14972
- MTFCI Number: 15411
I have a bin full of hubs - drop me a note.
- MTFCA Number: 51486
You need the correct fan hub. Also, the fan and hub should turn freely on the shaft, but there should be no wobble.
- Last Name: Rutt
So if I get the short fan hub I can move the top of the radiator back to fit the hood correctly, but can I move the bottom of the radiator back as well ?
The bottom spring mounts allow very little movement front to back - you'll need to loosen the bottom hose also - obviously, the top is adjusted with the brace rod & the upper hose.
- Last Name: Rutt
Ok.. thanks for the help.. ill put a short hub on and move the top back, maybe that will help a bit at the bottom as well.. even if the bottom doesn't move much it will look better..
