Ring a bell?
Dropacent
Last Name: Morsher
Ring a bell?
Post by Dropacent » Fri Apr 16, 2021 2:02 pm
Does this ring anyone’s bell? All brass, came with a bunch of carb parts. To me it looks like some sort of primitive carb,
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Re: Ring a bell?
Post by Joe Bell » Fri Apr 16, 2021 2:51 pm
Looks like part of a shift steam whistle?
jab35
Last Name: Bartsch
MTFCA Number: 30615
Re: Ring a bell?
Post by jab35 » Fri Apr 16, 2021 2:57 pm
or a relief valve.
Alan Long
First Name: Alan
Last Name: Long
Re: Ring a bell?
Post by Alan Long » Fri Apr 16, 2021 9:53 pm
I’m with James,
Looks like a very early relief valve due to the easing gear lever
Alan
MTFCA Number: 51486
Re: Ring a bell?
Post by TXGOAT2 » Sat Apr 17, 2021 11:21 am
It appears to have a fuel bowl and adjustable jet. Perhaps it had some sort of cylindrical, variable venturi piece that had a sliding fit in the body and was raised or lowered by the lever device to throttle the engine. I'm certain of one thing, I've never seen one of those, though I have seen some very old carburetors that had a similar general layout, but with a butterfly type throttle and choke. If it is a saftey valve or even a whistle of some sort, the bowl (if it is one) could be some kind of adjustable dashpot.
Last Name: Seth
Re: Ring a bell?
Post by perry kete » Sat Apr 17, 2021 5:36 pm
Just because they are bolted together doesn't mean they belong together. Someone at one time may have been trying to modify a piece of equipment and bolted them to each other.
2nighthawks
First Name: Harold
Last Name: Schwendeman
MTFCA Number: 0
Re: Ring a bell?
Post by 2nighthawks » Sat Apr 17, 2021 7:02 pm
It does appear to maybe be some sort of steam engine or boiler appliance,...perhaps an injector?
MTFCA Number: 24868
Re: Ring a bell?
Post by Jerry VanOoteghem » Sat Apr 17, 2021 7:07 pm
A sometimes forum contributor, Jeff Versteeg, had one of those at Hershey a few years back. Neither he nor I knew what it was then. Maybe he's learned since and can comment. (I'm as dumb as ever... :( )
Last Name: Gregush
MTFCA Number: 52564
Re: Ring a bell?
Post by Mark Gregush » Sat Apr 17, 2021 7:45 pm
You might try posting it here; https://www.smokstak.com/forum/
There are a couple of forums there that might get an answer.
https://www.smokstak.com/forum/forums/c ... ivery.156/
https://www.smokstak.com/forum/forums/s ... engines.7/
There may be some others there, so if you look see where else it might fit.
1920 Dodge touring
MTFCA Number: 51486
Re: Ring a bell?
Post by TXGOAT2 » Sat Apr 17, 2021 7:48 pm
If it says "Penberthy" anywhere on it, it's probably steam-related. It doesn't look like a steam appliance to me, or any type of high-pressure device.
Dropacent
Last Name: Morsher
More info. Ring a bell?
Post by Dropacent » Sat Apr 17, 2021 9:11 pm
Thanks all. It’s encouraging another has been spotted. That indicates it likely not a one-off. Perry keet, examining it closer tells me these parts have always been together, but possibly something else missing. I believe it’s oriented this way, because that is a float with a possible drain valve wing nut at the bottom. It appears it would drain out the little overflow fountain. To me, very unusual that all these nice castings would have no numbers, mold marks, logo, nuthin! It takes some close looking, but I did find a 4 digit serial number, very small and hand stamped. The two side openings, 180degrees apart, show solder tinning. At first I thought maybe pipe(s) had been soldered in place, but no, some rings have been soldered in place, one to change the diameter and the other to cover up some machined holes. Pretty sure the top lever would control a barrel up and down , possibly to change air intake. Feel free to share pics anywhere else, I have trouble posting stuff on smokestack and others.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Re: Ring a bell?
Post by Susanne » Sat Apr 17, 2021 10:06 pm
I wonder... it's just a WAG, but It almost looks like a burner control valve for a boiler...
Dropacent
Last Name: Morsher
Re: Ring a bell?
Post by Dropacent » Sun Apr 18, 2021 12:14 pm
I’ve got some steam car friends. Perhaps that’s a good idea,I’ll run it by them. The source is important. I didn’t find this just laying around. I bought a huge pile of really good stuff out of the PNW. Originally, it came from a California collector. All really good stuff, hood ornaments, carbs and carb parts, dash clocks, emblems, accessories, do-dads. No junk. It’s the only thing I couldn’t identify.
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Ring a bell?
Post by dmdeaton » Sun Apr 18, 2021 3:00 pm
An old toilet valve 😁
MTFCA Number: 51486
Re: Ring a bell?
Post by TXGOAT2 » Sun Apr 18, 2021 3:21 pm
Toilet valve? It does somewhat resemble a Victorian -era Thomas Crapper & Co. flush valve, perhaps a TC-3303-F with the much sought after adjustable lilac water dispenser feature... :lol:
rickg
Last Name: Goelz
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor, 1926 Coupe, 1923 popcorn Truck
MTFCA Number: 24965
Re: Ring a bell?
Post by rickg » Sun Apr 18, 2021 3:33 pm
Looks like it may be a steam trap to manually release water and steam.
