Rear Axle Mystery Part
Posted: Sun Mar 10, 2019 6:04 pm
by Redleg
T Teammates,
Can someone reveal the function of this modification on the rear axle?
Thanks,
John
Re: Rear Axle Mystery Part
Posted: Sun Mar 10, 2019 6:11 pm
by HaroldRJr
.....an air vent to hopefully aid in the prevention of gear lube gradually leaking out thru' axle bearings due to rear end temperature change expansion.
Posted: Sun Mar 10, 2019 6:19 pm
by RustyFords
Looks like a homemade breather for an axle that has had modern seals installed.
With that hose barb, you could run some rubber hose to a location of your choice.
Posted: Sun Mar 10, 2019 6:20 pm
by John.Zibell
Yes, home made breather. I'd attach a long hose with a loop in it and attach the upper end up high to prevent water entering the rear end.
Posted: Sun Mar 10, 2019 9:26 pm
by Redleg
Thanks, gents.
Posted: Sun Mar 10, 2019 9:39 pm
by Original Smith
Messed up a nice axle housing. The stupid things people do!
Posted: Sun Mar 10, 2019 11:31 pm
by TFan
Maybe it's for air pressure, hook a hose up to it and an air pump and pressurize to keep the oil up in the engine. :lol: Jim
Posted: Mon Mar 11, 2019 5:44 am
by Kaiser
:D First T with Airride system fitted ? :lol:
Posted: Mon Mar 11, 2019 6:36 am
by MichaelPawelek
This was the first perpetual motion automobile. Hot air made by friction in the rear end was naturally pumped into the number four cylinder where the pressure added 30 miles to each gallon of gas used. The project was squelched when Henry found out the fitting would add 3 cents to the price of the Model T.....
Posted: Mon Mar 11, 2019 3:58 pm
by George N Lake Ozark
My car came equipped with an oil fill cap.
