My 1927 Model T Coupe Restoration
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
The restoration of my 1927 coupe is underway. I will post photos as it proceeds. Hope you will find them interesting. I have 27 photos to post now. Can I include all of them in one post? Any suggestions on how best to do this and how to continue to record the restoration over the next several months?
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: My 1927 Model T Coupe Restoration
There's a limit of five photos per post. You have to post five, then five more in another post, then five more, etc. Sometimes it's kind of annoying, but that's the way it is.
- Last Name: Patrick
- MTFCA Number: 50126
You can post them all in the same thread. Simply start your thread, post 5 photos, then “post reply” to your own post and post 5 more then continue in this manner until all photos are posted. It will appear that they are all posted together, with only a couple of small identifying lines between every 5 photos. You can also post any remarks you have for each set of photos. It would be advisable to do this late at night so your photo sets are not interrupted by a poster. Jim Patrick
- First Name: Bruce
- Last Name: Brakke
The first photo is of my Mom and Dad with the coupe in 1959 during the 75 anniversary of my home town in North Dakota. It was in the parade. It hasn't been run in the 62 years since. Hopefully, it will be in the next few months. The second photo was taken last fall just before we started to disassemble it.
- MTFCA Number: 51486
That's a very solid looking vehicle. How did the chassis come to be painted?
- First Name: Bruce
- Last Name: Brakke
Last one for now. The frame has not been painted. It has just been blast cleaned to bare metal!
- First Name: Bruce
- Last Name: Brakke
One of engine ready for shipment to rebuilder and one delivered to Fastenal.
Excellent. Very solid, clean body. You’re in for a lot of fun. Jim Patrick
- Last Name: Gould
Very interesting. Nice work. Please keep the photos coming!
Yes and continue using this same thread so the pictures will stay together in chronological order for an unbroken visual record of your progress. Jim Patrick
- First Name: Bruce
- Last Name: Brakke
One small step for the restoration project. One large step for us.
- Last Name: Govoni
- MTFCA Number: 32331
Wow you guys are fast. Nice work on the frame. Are you going to pull the rear end apart?
Nice, clean floor.
- First Name: Bruce
- Last Name: Brakke
Robert, I have watched the three Model T-Tips videos about rebuilding the driveshaft/rear axle and am undecided on what to do, do it ourselves or by a professional.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Based on the pictures you have posted, doing the rear axle will be a snap, just dive in and learn. When I broke an axle shaft on my standard rear end, I decided to buy a used small drum Ruckstell and rebuild it to install in my T.
Here are some threads and pics covering the process. I had never done a standard Model T rear end before, much less a Ruckstell, but it turned out fine.
http://www.mtfca.com/discus/messages/70 ... 1494138378
http://www.mtfca.com/discus/messages/70 ... 1495119944
Keep up the good work
- First Name: Bruce
- Last Name: Brakke
Pat, I forgot to answer your April24 question. The frame was not painted. It was blasted cleaned to bare metal. It does look like gray paint. The primer is going to be Rust-Oleum gray, so I have added two half pints of Rust-Oleum prime brown to have a contrast when painting it.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
I think they are about $20 each. I have three under each car.
Your choice. Metal or plastic. Both will work.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Looks good Bruce, keep up the good work.
- First Name: Bruce
- Last Name: Brakke
Prime coat being applied. The odd color of the prime is because I tinted the gallon of gray with two half pint cans of rust color. I did this because the gray was almost the same color as the sandblasted bare metal.
Brush applied Rustoleum Gloss black Enamel. Great choice. Looks great! Jim Patrick
- First Name: Andrew
- Last Name: Blaydon
My brother, Dan B, rebuilt his Russell last year. He posted a thread with some of his insights. Might be of help to you.
https://mtfca.com/phpBB3/viewtopic.php?f=2&t=17157
- First Name: Bruce
- Last Name: Brakke
Is there a way to delete some of the replies to my restoration photos just to make following the restoration process easier?
The only way you can delete your post is if no one has responded to it, however, you can remove your long post by deleting the post, line by line and post a shorter message in order to shorten the thread, which is what I just did to my threads that had nothing to do with your restoration. Just make sure your new message has at least 10 characters. Jim Patrick
- MTFCA Number: 24868
Bruce, knowing you wanted to shorten this thread by removing posts that had nothing to do with your restoration, I went through and deleted my long post with the three books and my post with the oil pan. I was unable to totally delete them, but I was able to delete the pictures and delete the message, line by line and post short, 10 character encouragement messages in their place. If there are other threads of mine you wish me to remove, please let me know. In the future, anything I post on this thread will be short and on subject, reserving the space for you to document your progress in pictures and comment. Maybe others can do the same. I hope this helps. In order to save space, I would suggest that you ask questions in separate threads and post the results of your decision on this thread. Jim Patrick
- First Name: Bruce
- Last Name: Brakke
Jim, Thanks again.
- First Name: Neil
- Last Name: Martin
I do hope young Bruce Jnr is wearing EAR PLUGS while using the Grinder, Great thread..n.
- Last Name: Codman
Beautiful work!
Did you check out and clean the gas tank? If old fuel was left in the tank, it could set up like varnish and be very hard to clean. Also the fuel line and vaporizer must be completely clean too.
If the tank had been drained, it could have had water or condensation in it causing rust.
- First Name: Bruce
- Last Name: Brakke
Up date. A photo by the rebuilder showing the engine being boxed for shipment to me! I am anxious to see it!! Complete rebuild with new upgraded camshaft. I shipped it by Fastenal and being returned by Fastenal. I found them very accommodating and very reasonable cost wise.
- First Name: Bruce
- Last Name: Brakke
The rebuilder send me a video of the engine running at his shop. I LOVED the sound after 60 years of not hearing it!
I wish I could share it with you here.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
That will give it a new life. Its exciting to get a good power plant and hear it run the 1st time. Makes me smile every time. Thanks for the update. Keep em coming. I have been too busy for T time this fall but enjoy others progress almost as much as my own.
- First Name: Chris
- Last Name: Barker
What happened to the Vaporizer?
- First Name: Bruce
- Last Name: Brakke
Chris, I decided to use NH carb.
- First Name: Bruce
- Last Name: Brakke
I rebuilt a 1926 NH carb for my 1927 coupe. Here are some photos.
- First Name: Bruce
- Last Name: Brakke
I rebuilt the coil box using the waterproof material and the original contacts, photos attached. I cleaned the contacts using the toilet cleaner, "The Works", per a suggestion by the Coilman. It worked great. He rebuilt my coils. What a great man to work with, very professional and always willing to answer questions and offer helpful advice!! I will coat the coils using linseed oil per his suggestion.
The contacts are soldered. I used the screw rivets that came with the rebuild material to attach the contact strip to the bottom and the vertical contact plate to the box frame. I may replace them with pop rivets.
Four more photos on next reply.
- First Name: Rudy
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909 1913 1914 1915 1926
Looking good Bruce, I remember when you got the car. as I recall the man you got it from had a brother that had one like it too. I don't know what ever happened to that one. I don't know if you have heard this but we lost Kirk a couple of weeks ago sad time for me. Rudy
- First Name: Bruce
- Last Name: Brakke
I forgot to include these photos in my first post.
- First Name: Bruce
- Last Name: Brakke
More photos. Screw driver in second photo was used to spread the channel.
- First Name: Bruce
- Last Name: Brakke
More photos. Two leaks in the round tube radiator.
- First Name: Bruce
- Last Name: Brakke
More photos. Last two should have been with the post that has the radiator.
- First Name: Bruce
- Last Name: Brakke
Sanded the handle with 220, 400, 800, and 1000 grit.
- First Name: Bruce
- Last Name: Brakke
Head lamps and radiator apron restoration. Back side of apron primed.
- First Name: Bruce
- Last Name: Brakke
Splash panels painted and restored items in storage shed waiting for body to be painted.
Wow, great job on the paint!
- First Name: Bruce
- Last Name: Brakke
Fender and running board restoration and headlamp rod, apron, and splash panel.
- First Name: Bruce
- Last Name: Brakke
Photos in the paint shop. First one shows the sample of the maroon color for the body.
- First Name: Joe
- Last Name: Bell
Look like twins.
- First Name: Bruce
- Last Name: Brakke
The body is painted. I took Ardith to see it at the paint shop. She liked it! Will bring it to the garage on Monday.
- First Name: Marc
- Last Name: hall
- * REQUIRED* Type and Year of Model Ts owned: 1924
Amazing!!! can you tell us your choice to rebuild the engine ? you can pm if you like. and the radiator also. tx love all of these.
- First Name: D
- Last Name: R
- Board Member Since: 2004
Cool build. I like your color choice.
Did you have to replace the door glass channels? I'm trying to figure out how to do it for my '27 Coupe.
- First Name: Bruce
- Last Name: Brakke
Reinstalled the gas tank. New pad between the tank and cowl, new pads on the straps, new adhesive pads on upper tank supports, and new sediment bulb.
Bruce. How do you plan to remove the dents from your radiator shell? The dent on the front is very deep. It can be done. Have you nickel plated it yet? Jim Patrick
Check out: Www.Paulschrome.com. A place like this specializes in putting out perfect work.
Bruce. Be sure to install the chrome (nickel) plated trim piece on your radiator apron. It makes a real difference in the appearance of the front of your T by framing the radiator in silver, all the way around and across the bottom by joining the legs of the shell. I have posted pictures of a T with the trim and a T without the trim to illustrate the difference the trim makes. They should be available from Lang’s or Snyder’s. The 3 pictures I posted of the trim are of one I sold on eBay last year. Notice the hole on the left to accommodate the brass choke wire. Jim Patrick
Bruce. You may find that the right and left rear body blocks will not fit. At least that was the way it was for me. Hopefully, you saved your old rear body blocks so you will have a perfect pattern with which to revise the new ones to the right size. Please see the following thread I wrote back 2010 when I was seeking advice as to why the rear block did not fit, so you can see what I mean. It turns out others had the same problem and it was not my imagination: www.mtfca.com/discus/messages/118802/125665.html. If you find you are in the same predicament, you will need a table saw to revise the rear blocks so they will fit. Good luck. Jim Patrick
PS. It is possible that, in the 12 years since 2010, the problem has been corrected and the correct size rear blocks have been provided. If so, you can disregard this thread.
- First Name: Bruce
- Last Name: Brakke
Powder coated the wheels. One small step, but a huge step for the restoration project!
- First Name: Bruce
- Last Name: Brakke
Another small step, mounting tires on four of my wheels.
- First Name: Joe
- Last Name: Bell
Looking Good!
Looks great! Don’t forget to install the spring leaf alignment clamps on your springs to keep the leafs in line. Jim Patrick
For others' information. Modern tyre changing/mounting machines will accommodate 21" wheels . With a bit of tape on the three mounting claws, powder coating can be protected. The fitter can adjust the machine so no other part ever touches the rim. It will roll the tyre around without ever touching the powdercoat. The tube can then be inserted and the outside bead rolled on in the same manner. No masking neded. No damage to the paintwork and best of all no cussing because of damage. Much safer than wrestling with them yourself.
Allan from down under
- Last Name: Govoni
Incredible work!!! What a nice car.
- First Name: Bruce
- Last Name: Brakke
Windshield Installed.
- Attachments
- IMG_3365.jpg (19.48 KiB) Viewed 3978 times
- IMG_3368.jpg (21.36 KiB) Viewed 3978 times
- First Name: Bruce
- Last Name: Brakke
Photos of installation of top and interior material.
- First Name: Bruce
- Last Name: Brakke
Photos of top installation. First photo is taking the original rain gutter apart. The inside piece was replaced with a piece of tape measure.
- First Name: Bruce
- Last Name: Brakke
Repair of top wood. The last photo is the corner after soaking it with the "Wood Harder".
- First Name: Bruce
- Last Name: Brakke
Repair of top wood frame with "wood harder" and "wood filler".
- First Name: Bruce
- Last Name: Brakke
Bleeding the "SURE-STOP' disc brakes by Birdhaven. The first three photos are of bench bleeding the master cylinder and the fourth is bleeding the calipers.
Too bad your Mom and Dad aren’t here to see your work. They’d be proud. I notice in your first pictures, there is no sun visor. Were you planning to install one? They really are essential to the appearance and accuracy of your restoration. If you need them, I have pictures of the way the sun visors were originally installed, covered and stitchedI, that I can post. Jim Patrick
- First Name: Bruce
- Last Name: Brakke
Jim,
Yes, I will install a sun visor. I purchased the cover from Classtique. I believe installing it on the original frame is going to be difficult. Anything you could provide would be helpful. Put it on a new post.
Bruce
Bruce
Removed by poster.
Removed by poster
Removed by poster.
- First Name: Bruce
- Last Name: Brakke
Starting to put the splash pans, running boards and fenders back on the coupe.
- First Name: Bruce
- Last Name: Brakke
Organized in preparation to install the fenders and radiator!
